From his posts it seemed like the last one failed when it had only had light use - if it had already had some hard track time then it'd not be too surprising, as you say... the plastic caged ones aren't too flash but the GTX ones have the steel bearing cages I believe, which make them a lot better suited for that kind of shenanigans. I love it that the Kandos are more reliable, we have turbo builders in NZ trying to convince us all that they are grenades.
Forged rebuilt rb26
Precision 6266 t4 divided .84
GFB EX50 wastegate
Adaptronic
Greddy 264 cams
BC valve springs
2000cc injectors
Walbro e85 450lph pump
Plazmaman front mount
448kw @ 24.5psi - caltex e72
Forged rebuilt rb26
GFB EX50 wastegate
Adaptronic
Greddy 264 cams
BC valve springs
2000cc injectors
You need a bigger fuel system :P
Great result man you have me thinking again....bastard
Yeh but I'm very impressed how much these walbro e85 pumps flow
There was no sign of it running out yet either but decided to stop to be safe
Nick do it !! U no you wanna :P precision for sure ditch the twins lol
How far are you guys pushing your 6266 on pump fuel. I only have access to 98 RON here and pushing around 1.7 bars on my rebuilt 26/30. I'm so tempted to push it to 2 bars with RB30/26's low compression.
Edited by G37Sam
Should receive my crg manifold tomorrow latest the day after then bolting my 6466 with my precision wastegate, purchased all the gaskets so motor should be ready to all go in hopefully this week and get her cranked over ;)
Anyone have to have their rear housing machined to seal properly with a v-band flange.
I bought a T4 6266 and it didnt come with any exhaust flanges.
My fabricator spoke to a reseller and was told you need the Precision 3-5/8 kit and also to get a step machined on the rear housing?
AFAIK the precision kit w/clamp and flange is all you need? Spoke to Rotormaster and he said with the precision kit, it should be all you need.
Edited by n_D
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
