that one is defs a 2.8, asking for ya boi vims see if there is a graph for a 6870 on a 26
Think it made over 800rwhp for about 3000rpm which is just silly!
Not sure on a 2.6L, it would shit out power but be fairly laggy. Doesn't vims want a track car?
Id agree with that, some good results happening on 3.0L and 3.2 stroker kits with the 6870 from what im seeing around.
Could be OK for a 2.6 if a small enough rear housing is selected, but it would be a issue up top end when at song. (depending on how hard you pushed it)
Very very nice mate must come on song strong !
6466 is still my fav turbo, seen results range from 500- to over 600kw
No need for dirty big 6870's and 7175's etc
Haven't got it back yet. Imagine it would push towards 600 with another 3-5psi like other results I've seen.
Definitely a good choice for E85.
Do you have a dyno graph or 38psi 2nismo?
I saw a dyno result of a 6870 on a 2.6 today with cams, low 30ish boost, make mid 500'sKw, was as laggy as hell, not very impressed, looked like a slug to drive on the street, nothing then all.
Seen a few like this so far on 2.6's, seems like the 6870 is more towards the extra 15% capacity that a 3.0L or stroker delivers.
Looks like 2.6's run a larger area under the curve on the 6466....
It's a 1100hp turbo on a 2.6L, it was never going to be responsive. I would say my 6262 is right in the sweet spot for a 2.6L non drag application but it's rated at 705hp.
6466 would be a good all rounder for a 2.8L and a 6870 isn't too bad from what I have seen but more towards a drag power band.
I completely agree, 6262 or BW EFR 8374 is the biggest I would go on a real streetcar, up to 3.0L. I wonder how far off the compressor maps the 2.6 is with some of these giants? And I guess I will keep wondering because Precision doesn't need no stinkin' compressor maps!
Edited by HarrisRacing
No point until it has enough injector. Then you'll see the whole thing. Ethanol and a torque converter fill the hole that might otherwise be there with a petrol/manual.
