Finally had the tune...
So stoked for the little rb25 with 647 hp @ wheels on 28psi.
It actually comes on the converter 200rpm sooner than the to4z.
I need cooler plugs and a bigger wastegate and it should make 700hp pretty easy as the 647 was with early shut off cos of break down and boost creep. image_11.jpg
  • Like 2
I am about to go down the 6262 (0.63 rear) path on my rb25. I'm chasing 280kw ish low boost and 320 - 350kw high boost. Engine is built and has supporting mods. Just unsure as to what gate pressure I should run for low boost. Fuel will be 98. Was thinking between 16-18psi low and 20-22psi high.
Small rear housing plus 98 isn't a very good idea imo.. I made 288kw on a GTX 3071 on 98. Id look at something smaller than a 6262 for 280kw.
That kinda power can be had on a stock lowmount position kinda turbo.
Big $$$ changing manifolds and plumbing up EWG etc for a laggy 280kw - 350kw IMO.
Edited by Mick_o
I drove a supra locally here that makes 350kw @ 16psi on a gt3582 with a 0.63 housing on 98. Looking to make 320kw+ in the high boost region, so it must be able to get there if the 3L can do it without it choking. If I have to run a little more boost to get there I will. Just trying to work out what spring I should be running in the gate for low boost to roughly get in the 280kw area.
5858 0.84
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
