3.4 stroker I believe, but that won't affect peak power much
It was only a ~6500 rpm run apparently as the dyno wouldn't run past 230kmh for some reason.
Unsure of rear housing, but assume it's a bigger one....
3.5" exhaust, with gate plumbed in, so, far more potential to be had yet.
Also, I ran my car and it was fairly consistent with how it was tuned on another dyno.
  • Like 1
That's impressive, not just peak power but down low as well.
I wanted to know the capacity as I'm planning to run 30psi (2.7) and hoping to get 850hp from the 6870
But it seems likely I won't get there.
Why only 30psi? What fuel? If e85 why are you limiting yourself?
Yes it will be on e85, I'm after a safety factor as this is a brand new engine and its street driving.
I know I can make 1000hp but where do u draw the line?
I'm drawing the line at a safe 30psi Street driven all day long, then pushing it to its limits just for a numbers game!
At power cruise events it will be pushed upto 950hp with gas. Also my engine hasn't been sleeved and has stock girdles, so that's mostly why I'm holding back.
Edited by QUP29
Thats a 20odd psi safety margin.
1000hp on stock girdle and no sleeves isn't an issue.
Especially as its only going to be pushed sometimes.
Me and my tuner know it can make whatever we want it to make, the motor is good for 1200hp but I'm not about pushing it to its limits.
His seen N1 blocks crack at 600-700hp.
It's a street car, and I want it to last as long as I can as this engine isn't just a normal off the shelf stroker kit!
Edited by QUP29
I've seen brand new cars off the showroom floor break as well.
Got a thread on what makes the 2.7 different from a readily available off the shelf 2.7?
no I don't have a thread if that's what your asking? I have different components from just your normal off the shelf nitto 2.7 kit.
But enough about me this is a precision turbo thread, sorry for getting off the topic.
Back on Topic, a 6466 would/should/will go very close to your 850hp number on 30psi.
A high comp 2.6 down here makes 608kw on 26-28psi he runs 35 on the track.
Yeah i have mentioned a have a sweet spot for the 6466, we originally had the 7175 but I chose to change to 6870 for a better spool.
6466 won't give me 950hp maybe on kill mode!
6870 gives me more room if I do change my mind and want to push the envelope
Thanks for the info
Edited by QUP29
Thanks for the info
Will be interesting to see what it puts out at 30psi. Take into account that graph has a very restrictive exhaust setup so probably not much above 30-32psi with something free flowing? I'm only guessing
Started working on the car again.
Ended up going a 6466 with T4 divided 0.84 rear on a Rex Kelway twin scroll manifold, twin tial 38mm gates with Plazmaman plenum & throttle body. Will be on a SR22VET circuit car. Hopefully will be ready in a few months time so will see how it goes.
This is one of the big questions I was looking for initially as well. I have a new N1 block on stock bores and a BC stroker (makes it 2.75L)...I decided NOT to grout my block because I too am limiting myself with turbo size (BW 8374 EFR)...where should I stop? I was assuming I could max this turbo out on my setup if I wanted to and the block would be fine. Again street car with some lapping days in it's future so I was erring on the low end / reliable side of things.
I made just shy of 500kw at 6300 rim with a 6466 while still tuning top end. That block died a painful death, along with my wallet. The 6466 at 35+ pound should see 600+ on a well built stroker with a good head. I love good head.
The 6466 see's over 600kw under 30psi on 2.6 and strokers.
A stroker means less rpm more than anything
As for blocks need grout etc. Many cars over 1000hp don't and haven't
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
    • Well, you wouldn't use 2nd hand bearings out of another engine anyway....so just buying the proper bearings is obviously what you're going to do. The crankshaft would be common. The conrods might be common. There is essentially nothing else you would be able to use.
