Opinions on a 6466 w/ .84 TS on a built 2.6 with 272/272 10.2mm lift cams?
I have poured through this thread, and as such was leaning towards the 6262 or even considered the 6062 Gen2 thats just been released - but my engine builder is telling me the 6466 is 100% the go
I trust the workshop, but just want to double check other's results; dont want something that comes on at 5k or later.. id rather it come on hard at 4.2-4.5k rpm
Its concerning seeing people say a 6466 outflows a T51R
A rb30 usually adds about 500rpm response all things equal... My cams are bigger than yours, so you could possibly base it off that. I'm using a 1.0 divided housing.
I don't think it will be bad, certainly better than a T51R in response, even if it does flow more top end. Thats the beauty of new technology.
If you're worried about response though your are probably better off with a smaller turbo, unless you have a power figure you definitely want. Take into account the 6466 is a 600awkw turbo
Depends on car use, I'd be giving a 6062 a go if your stuck between the 6262 and 6466 for a decision. It should sit right in the middle in response and power :)
I try and do everything with my car from tight sprints, circuit work,1000m drags and powercruise etc. and the 6262 is right in the sweet spot of power and response. I actually turn it down 140hp for everything apart from powercruise and drags because it's more than enough. What do you want from your car?
A 6466 is going to be responsive for its size but it's getting towards drag car only power band on a 2.6L, if that's what you want then go for it but your never going to keep up with the Jones's.
What would you guys recommend for. Street drag VL, auto re401a
Forged Rb30 NEO head
270 9.2mm cams
Plenum etc etc 3k stall
Currently running gt35 .82 internal gate
22psi 422hp but out of injectors
98ron
I was looking at the 6466
6466 1.0 divided.
I make 433awkw on 22psi, 98
100kw more on e85
Should be plenty to run 9's
It's been a while but here is my Dyno sheet from build
Rb26 precision 6262 at 19 psi.
Car is running good other than its smoking from turbo.
Anybody here using restrictors? I just put a .030 restrictor and stopped smoking but not sure if I should drive it.(n1 pump)
EC990DBB-75E3-4453-89C1-EC9B0C5E4339_zps
Thanks for the quick reply guys. Haven't removed the factory restrictor. I'm running a -4an feed line and a -10 am drain line. Drain line is pretty straight down with now kinks. I also did a leak down test and compression test on the engine. Got 128 psi on all 6 cyl.(running 8:3:1 CR) and dry leak down test was 10% on al 6 but #1 13%. Not sure what other options I have
I'm getting 45psi. Pressure at 2.5-3krpms and over 60 psi from 4k up
Edited by silvianc
Is that America?
because that is epic power in Australia for that boost
Lol yeah. I'm in the U.S.
Setup made
390hp@9psi
450@11psi
560@15psi
611@19psi
This is on a 2.6, 87mm pistons and Tomei type B cams, t4 .84 divided housing and limiter on 8400 Rpms but u can see dyno sheet actually was 7.8k Rpms
https://m.facebook.com/story.php?story_fbid=773329676088103&id=142284982525912&_rdr
Our horses are angrier
Hell yeah. I'm in the USA too. Here I am thinking of seeing 550 whp on pumpgas and I'm at sea level and I'm on a stroker motor. Heck I may see 650 whp on pump after seeing this !
You'll probably see 550 Australian horses if you've been looking at our graphs. More if in USA
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
