Precision Billet Turbos
.84 housing!! Simply won't take more boost. You wind in 30psi+ and it just drops down to 25-26psi. No restrictions in cooler etc, even tried a plazmaman 100mm cooler and it's still same.
6 hours ago, Buraz said:
What's everyone's results with 6262 precision??
My is out of puff at just under 440kw and 26 psi on a 2.8l stroker
Mine has gone 560kw at the hubs. 440kw sounds significantly lower regardless of the dyno. Got a graph? Any restrictions?
Ahhh okay!! That's a big difference for sure. No restrictions whatsoever, it's a split pulse 6 boost and twin gates too. 17.5psi springs!!
Car hammers no doubt about it and I'm more than happy. Just thought I'd share my results with you guys and see other results
Oh wow that's a massive difference!! Is it same rear housing as mine?? After talking to a few people now, this thing is only a tiny turbo and tell me it's about right.
But yours is an unbelievable result. Still a 2.6?
  • 5 weeks later...
Mine should be hitting the dyno next week hopefully
previous tune was 645kw at 34psi with a 7175 gt42 on a hks 2.8
few changes since last tune such as 100mm plazmaman cooler and turbo1 custom twin scroll manifold with twin 38mm tial gates,
should come on nicer now then it did with the old greddy stainless manifold
  • Like 2
  • 1 month later...
How did it go?
I am quite interested to see how much difference a manifold makes.
I have a 6766 on a T88 Greddy manifold and have access to a 6 boost if the need arises. The car makes 460 odd rwkw @30psi on Unigroups dyno and traps 138mph but I still want more.
Have been told I should have gone the 6466 as its better suited to an RB26
Edited by ido09s
On 26/06/2017 at 11:22 PM, SimonR32 said:
The 6262 sillyness is never ending... New cams just got the most power and torque it's ever made
Lol what..
760 awhp on a turbo rated to 705hp.. not questioning your results but that is going to be overspeeding by like 30%
Very impressive that it's still happy pushed that hard. I'm interested in your exhaust back pressure and compressor outlet temp numbers.
Dynapack hubber gives a possible 5-10% inflated reading.. However simons back to back results with his setup and different cam combos are awesome and the car speaks for itself performance wise..
Its unfortunate that the next time its dynoed it wont be a true back to back unless you can sweet talk sean and he has access to the dyno still
Edited by azzada1
6 hours ago, burn4005 said:
Lol what..
Technically it's rear hub hp, not awhp. I don't think they have an overspeed (it's not an EFR after all)
Turning the dyno on SAE correction it shows up 797hp so god knows how much it's making at the flywheel but definitely more than the turbo is rated at. Never measured backpressure in exhaust but air temps after the intercooler are more than reasonable
its frustrating that no compressor maps are available for precisions because a turbo compressor power rating is usually based on an efficiency below 58% or even the stonewall flow (flow choke) of the compressor. this is the speed that part of the assembly reaches sonic speed and flow basically cannot be increased any further by spinning it faster or altering the downstream pressure. thats why the choke line is vertical in a compressor map. (although note that maps from garret state efficiency below 58% is the end of their displayed map, and they consider that point "overspeeding") It's not necessarily when it wants to fall apart, but the efficiency falls over and then finally the compressor won't flow any more due to sonic shock waves inside the compressor inlet or volute causing a choked flow condition.
its interesting that the Precisions seem to be happy well past the flow the manufacturer rates the compressor for. whereas Borg Warner made their turbines strong enough to cope with the choke speed of the compressor they paired it with and not much more as its outside the design parameters.
Edited by burn4005
  • Like 1
    • So next year I am looking at upgrading from my VE SS bomadore ute to something more refined.  I wanted to stick with a V8 but not anything German or Australian, either a coupe or a sedan. So if I wanted anything newish that limited my options to either the Lexus RCF which I quite like. But with the price they demand and a kid on the way a 2 door coupe is probably not going to be the best idea. The next best thing would be the ISF but the newest models are 2014 and commanding over 60k and even the older 2008 models in ok condition starting around 35k is kind of bullshit. So I figured if I could not have the noise I could perhaps make do with easy power. Enter the infinity Q50 or Skyline equivalent. The price difference between the 300 and 400hp models seems a bit crazy. Right now there is 300hp Q50 one on carsales from a dealer with 61km for 27k drive away. If I wanted to get a 400hp Red or 400R car the prices seem to start at 43k From my limited research it seems that the only differences are that the 400r/Red Red runs more boost and a more aggressive tune. There are are turbine speed sensors on the turbos. Has 2 pumps for the water to air intercooler. Runs an engine oil cooler. I'm guessing that the exterior trims might look a little more sporty as well. I had a lazy look for upgrades to bridge the gap on z1motorsports They have kits that upgrade the water to air heat exchanger as well as the coolant pump which should give a non Red/400r better intercooling temps than the stock Red/400r. I added an engine oil cooler with a thermostat as well to try and make things as close as possible. Obviously the ECU is going to need a tickle. Having not done much in the way of research they also sell a ECU flashing tool with pre loaded tunes that are supposed to boost the non Red/400R by 100hp which adds 1k USD to the cost. The total cost of the parts @ the current time including shipping and taxes worked out to be $4350 AUD. Personally I would rather get the car tuned on a dyno which would probably add more cost Assuming the worst that you got a workshop to install the new parts I would guess no more than 5 hours would be required in the worst case @ 5 x $150 per hour = $750 So the total cost could be around $5100 So for easy number 5k + 27K = 32k I guess that would leave some change left over to swap out the open diff and fit a LSD Any thoughts?
    • Right, not sure why I thought it to be a lean spike. It might be fixable with modern card-style hot film MAFs which have some design features to avoid counting reversion flow but I've never tried it myself.
    • I did not realise this, I'll contribute more and earn my stripes and retry later.
    • I'm only going to hassle you for posting links to images. It's against my policy to click links that could be some nasty payload. Sadly, you need to make 9 more posts before you can just stick the images directly in a post, unless @PranK sees this and bends the rule for you.
    • Hello,new to the group, I bought a R32 from auction recently, wondering if anyone knows the cars history, seems to have the usual go fast bits on it, plan is to do an engine swap- add 2 extra cylinders and 1 extra turbo. https://www.dropbox.com/scl/fi/i4rjmlzubjbwjtguh6f4s/IMG20241011140744.jpg?rlkey=q0lumm251377vknbqktfwrycq&st=7scvwx4e&dl=0 https://www.dropbox.com/scl/fi/ro24qmwzlczzlfsr4y05x/Screenshot_2024-10-10-10-49-23-90_9a2f5bb2149dae94cd1e190effc09b33.jpg?rlkey=oyguh26ttshlf04ccp48odf4v&st=xloae97b&dl=0   New to forums and posting pics, if links don't work, take it easy on me, 42yrs old and I tune carburettors!!
