24 minutes ago, SimonR32 said:
Direct back to back change... Same boost, 30psi
6870 made even more power with extra boost while the 9180 was all out
Yeah not too surprised that the EFR9180 was out, I would 100% expect the 6870 to outflow it - and by a bit of a margin.   The boost threshold however is a definite surprise.   Interesting how some results can vary!   Hard to know what to make of it.
On 4/25/2019 at 2:27 PM, SimonR32 said:
The precision is the ones that comes on way earlier and makes more power...
I'd like to see the transient response make up for that deficit
Which rear housing was on the efr?
  • 3 weeks later...
Hey all,
Bit of an update from late last year.
Precision 6062, built s1 rb25det, e85 etc
Got it tuned last year and it made 431kw @26psi apparently the turbo was maxed out. Dyno dynamics roller dyno.
I decided to change the wastegate springs from 14psi to 21psi, fixed a boost leak i found underneath the intake manifold ( idle control- cold start valve area ), hpi evolve radiator and decided to run a viscious fan again.  Might have been a few other minor changes.
We stopped at 29psi as we were a little worried about the arp 2000 headstuds not handling much more. Turbo seemed to be still going and I think we could have gotten a bit more out of it if the headstuds weren't a limiting factor.
This is on a mainline hub dyno so it is 710hp at the hubs. Still quite happy with the result and I'm sure the 6062 could keep pumping. I attached a video of the run, hopefully it works.
We used Real Dyno hub dyno and Brad Sheriff from Boost Automotive Tasmania tuned the car.
  • Like 2
  • 2 months later...
38 minutes ago, reaper said:
Nope haven't seen anything. I'm trying a 7275 this week and will compare to my old 6870.
What was the 6870 like? I know I could search this post but who the hell knows how far back I may need to go to find a post....
I have a 6766 with a 1.0 rear and I don't know if the lack of driving but its started blowing blue smoke the other day. highly unlikely to be the  engine so it might be time to up the turbo a little
4 hours ago, feedmyfast said:
Hi Guys,
sorry it has been so long. here are the results from my 6466 @40psi. The car is a different animal now, had to get some drag radials to put down the power.
What's the rest of your engine setup?
I also have a 6466 to go on mine.
S1 RB25, Kelford 270 cams, supertech valve train (stock sized), CP pistons (stock bore and compression), Manley rods, balanced crank/ block. Otaku manifold, ID2000s
  • Like 2
6 hours ago, feedmyfast said:
Hi Guys,
Have you raced it? what mph did it run if you have?
Edited by ido09s
Hi Guys,
Ha! That is ridiculous, nice work!  That's gotta be one of the more stout RB25 setups out there, being SAU people will probably make dyno comments but realistically - an RB25 with 270deg cams and 40psi pumped through it on E85 is going to make some serious power :)
What is the spool like?  There is no rpm scale on the dyno plot (NFI why people print plots like that), so a bit hard to tell.   Be very interesting to see how it goes at the strip, hope you have a decent trans! :D
Also very curious to know what the spool is like! Looks like it would be an absolute weapon, good job!
What turbine housing size - also single/split pulse + gate setup?
Perhaps drop something into the RB25 dyno results page
Strong result.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
