unfortunately not. Yavuz and my girlfriend went through the previous dyno runs so i am not exactly sure why they couldnt find something that was comparable. It was also becoming quite time consuming as we have used Unigroup for years and there are loads of runs that have been done on their dyno over that time so we kind of gave up on looking
It does drive a lot different and i am sure the drag strip will tell me its a different car.
Standard head studs and we dont want to lift the head. We are only using E-Flex without an ethanol sensor so had to leave some room for safety, and its only a street car ;)
I know many will say stock head studs should be fine but honestly, 485rwkw in an S14 is way more than enough for now. It leaves us some more power for when we get bored ;)
Edited by ido09s
Jez posted up on FB an update on his gtr yesterday. Stock motor, so studs and HG stock, and he lifted the head at 435 or so rwkw.
Oh, that's with a 6262
I couldn't imagine a 485kw S14....!
That is just silly :)
We went with the 6766 as the response is pretty much the same as the 6466 and it has the ability to make a bit more power. Its also made more power at lower boost which is always a good thing. Comparing it to the T78 we had on it its quite a bit more power for the same boost levels.
The plan isnt to stay that way trust me.
Next step is to get some head studs, an ethanol sensor and get it all sorted. Will put more boost in it and see where it goes. It ran 137mph on ET Street with about 420rwkw so see what it does with the new setup ;)
  • 1 month later...
Nice!
Precision are also about to release a few more of their new Gen2 CEA range - probably one of the more interesting to 'streetable' people fiends on here would be the PT6870, which is apparently rated to just over 1000hp. Will be interesting to see how that goes when results start filtering through.
Nice!
hmmm interesting will be definetely waiting for those.
Some of you may already know we temporarily made the jump to an 8285 on the SR and took it out with a no mercy attitude. It was going to either go mega fast or turn into a grenade. It chose the later option! Sprayed the track and in the process the tyres. We were on 58psi and all I can say is when it came on from 2nd gear wow....never felt anything like it.
Another close call with a wall, but in Flying 500 style managed to save it. Bottom end is carnage!! Glad I didn't wrap the car, I have plenty of SR spares.
http://www.youtube.com/watch?v=xACxbx6C6R8
And the incar...
http://www.youtube.com/watch?v=OivcTogApps&feature=youtu.be
Something spectacular was going to happen and you delivered :)
Im just glad you didnt scratch the roof!
Looking at the incar, oil pressure light at the top of second, engine rattled 3rd and BOOM 4th :(
wow is all i can say!!!!
Thats one hell of a save given there was no chute involved
Just curious PJ, is it just me or my lack of knowledge when it comes to cars as quick as yours, but does the engine bog down quite a lot on launch with your car? What 60 footers does it run?
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
