From his posts it seemed like the last one failed when it had only had light use - if it had already had some hard track time then it'd not be too surprising, as you say... the plastic caged ones aren't too flash but the GTX ones have the steel bearing cages I believe, which make them a lot better suited for that kind of shenanigans. I love it that the Kandos are more reliable, we have turbo builders in NZ trying to convince us all that they are grenades.
Forged rebuilt rb26
Precision 6266 t4 divided .84
GFB EX50 wastegate
Adaptronic
Greddy 264 cams
BC valve springs
2000cc injectors
Walbro e85 450lph pump
Plazmaman front mount
448kw @ 24.5psi - caltex e72
Forged rebuilt rb26
GFB EX50 wastegate
Adaptronic
Greddy 264 cams
BC valve springs
2000cc injectors
You need a bigger fuel system :P
Great result man you have me thinking again....bastard
Yeh but I'm very impressed how much these walbro e85 pumps flow
There was no sign of it running out yet either but decided to stop to be safe
Nick do it !! U no you wanna :P precision for sure ditch the twins lol
How far are you guys pushing your 6266 on pump fuel. I only have access to 98 RON here and pushing around 1.7 bars on my rebuilt 26/30. I'm so tempted to push it to 2 bars with RB30/26's low compression.
Edited by G37Sam
Should receive my crg manifold tomorrow latest the day after then bolting my 6466 with my precision wastegate, purchased all the gaskets so motor should be ready to all go in hopefully this week and get her cranked over ;)
Anyone have to have their rear housing machined to seal properly with a v-band flange.
I bought a T4 6266 and it didnt come with any exhaust flanges.
My fabricator spoke to a reseller and was told you need the Precision 3-5/8 kit and also to get a step machined on the rear housing?
AFAIK the precision kit w/clamp and flange is all you need? Spoke to Rotormaster and he said with the precision kit, it should be all you need.
Edited by n_D
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
