attachicon.gifImageUploadedBySAU Community1396264885.717947.jpg.
4828,s pictured with expreme manifolds someone was intending on bolting on a rb26........
seen this picture before, is it from a for sale thread lmaybe ?
Anyways, I bet they are not since I wasnt able to find any info about them on a skyline/rb platform.
7675 comp covers.
gt42 style vs hp.
different surge porting.
different outlet.
is the 42 really worth an extra $700?
im assuming they would have the same comp wheels.
anyone had a play with them?
Was leaning toward the EFR 83/74.. but my mechanic told me th journal bearing shouldn't be any laggier/sluggish than the same turbo with DBB. what,s your take on this for a 6262 ? With the journal worth 1100$, its a 1100$ +tax/duties saving over an EFR, it's worth considering haha :)
Its a matter of you get what you pay for.. Most guys in here are using the DBB option and paying over $2000 a turbo. I think it would be naive to a degree to expect to obtain the same results with a turbo half the price. Whilst I have no doubt their Journal Bearing option will still be ok, If i purchased one I wouldnt expect the same results as the DBB ones.
R
R
This is what I though too, but since I have high regards for my mechanic and some drift driver sponsored/great deal by PTE use his mechanic service so I thought his opinion about PTE turbos should be right. so MAYBE... journal bearing improved a lot in the last few years... I don't know lol.. this got me confused, but tbh, if I'm going to pay 2000$ for a PTE DBB, I might as wel bite the bullet on the efr I think :)
You are over-thinking it, the turbocharger should be sized appropriately (using a compressor map) to your engine... bearing type should be one of the last considerations.
Put it this way, I bought a Borg Warner S366 which has very similar size and design turbine and compressor wheels as a EFR9180 but is journal bearing and doesn't have the fancy material compressor wheel, wanky & ugly (IMO) BOV in the compressor housing. Cost me all of $750.00, flows the air that I need at the required pressure ratio.
Edited by bigmikespec
  • Like 1
7675 comp covers.
gt42 style vs hp.
different outlet.
It's twin scroll divided housing vs open. GT42 style also has a larger comp cover, that's the difference.
can get both with a t4 divided rear.
gt42 with 0.96, 1.12, 1.22 options.
hp with 0.81 and 0.96 options.
the exhaust outlet is bigger on the gt.
gt42 is obviously a larger front cover.
but, considering the same rear housing (0.96), would there be any difference to spool time or outlet temps?
has anyone done back to back testing?
I know an awesome tuner that now loves bolting precisions onto RB's and adding some E85 and some other magic and numbers happen :yes:
Hi Noy
Been waiting to see what the end result was. Any updates or did I miss it?
I am having PT6262 CEA SP installed this week
  • Like 1
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
