Seen the overlays as 6262 with give me a extra 1k rpm boost response and I'll be sticking in. Otomoto v cam for even more.
should do the job at the track at 15 psi and will also allow me a "street" high boost for when I go get a coffee on Saturday once a week
  • Like 1
Yea whats the go with the 6062.. any figures yet?
Is it the newest version of the 6262 basically?
Have not seen a result yet, but the 6062 is rated at 750 hp and the 6262 is rated at 705 hp.
What that translates into real works figures, who knows, but it's definately interesting. Smaller front fan but can flow more... Win win!!!!
Finally got the car with new Plazmaman intake manifold and 6870 to the track with an auto though...
9.60@140mph on 21psi
9.39 @ 144mph on 23psi
Turned it up to 40psi and the box doesn't want to play enough to head back to the track but it feels very strong. Hopefully back to the track in a month on 50psi.
Edited by PJ.
  • Like 2
Hmmm ok. I have driven a supra here locally with a gt3582r with a 0.63 rear and with the 3L and makes 350rwkw on 16psi. Granted it's a different motor, but it doesn't seem to choke it at all and response is insane.
I can't find any results on the 6062 gen 2 yet. Anyone got anything interesting?
For those who haven't seen it yet. The 6062 is rated for 750HP where the 6262 and 6266 is 705 and 735HP respectively.
Smaller turbos that flow more are always a good thing however these things need to be confirmed in a real world comparison! Just in case they've added more weight to the comp wheel which will affect spool up
All I could find with MR google was a 1.8L VW guy who did a boost vs RPM log and got 20psi by 4900RPM untuned.
Am I missing something?
Also is this the first release of a new line of Gen2 Turbos? It would be awesome to see this new design move it's way up to larger turbos for better spool vs Power.
double post:
Just saw the Gen2 6266 and 6466 are listed too. oops
800 and 900HP respectively
6266 Gen1 735HP
6266 Gen2 800HP
I'd love to see side by side dyno results
Im also keen to see results of Gen2 6062 and Gen2 6266 units..
Ive found 6466 vs. Gen2 6466 on a US Supra forum and it was identical spool, but with +30hp around the peak 1500rpm
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
