The 6466 see's over 600kw under 30psi on 2.6 and strokers.
A stroker means less rpm more than anything
As for blocks need grout etc. Many cars over 1000hp don't and haven't
sorry to keep steering this away from turbos, but BC (and myself as a mechanical engineer) feel that a billet chromoly crankshaft is considerably stronger than stock based on materials selection alone. The marginal increase in stroke (73.7mm stock to 79mm BC) therefore does NOT reduce overall usable powerband on the RB26 (ie I will not have to LOWER the rev limiter over stock when using this crankshaft). This is one reason you don't lose RPM with a GOOD stroker crankshaft in these engines. I think I will see how the car acts on the dyno and will likely still be keeping mine at the 8250 factory redline, but after talking to BC (prior to ordering mine) I'm pretty sure I recall discussing a figure in the 9k-9,500 on the crank with an insane HP rating...and I went with the lower duty "sportsman" rods...because I wasn't going to make more than 200HP per rod. The only difference between their sportsman and +625 rods is the fasteners. Rods are exactly the same.
Requires less rpm to make same power with any given same turbo.
Stock cranks will go to 10k no worries
Oh there are always worries at 10k rpms of boosted rotating mass at your heels!
But yes, everything I have picked for my setup is to keep the rpms lower and powerband more responsive. Cams, turbo, stroker, etc. I honestly think my bottom end will handle anything this turbo can give it. I have calculated that the 8374 EFR on my 2.75L stroker will start dropping boost sustainability (only 22 psi) at 8,500 rpms (max air flow of 79 lbs/min) but will be dropping power earlier at 7,500 rpms. Maybe I'll set the boost drop threshold as redline, but after seeing videos of how well the RB28 in the Z-tune responds (and from what it looks like an 8250 rpm limit), I'm thinking I'll be right there with their response level which will be fine with me.
And thank you for your input...it is appreciated. I don't want to sound like a know-it-all. After pulling an engine that suffered such massive rod bearing failure from my car, I'm thinking lower rpms and more displacement is what I wanted to go for - IE reliability. Of course I do not know the circumstances under which this engine failed as I purchased it with a rod knock.
Edited by HarrisRacing
it's not just the crank that will let you rev, need good head. Also dual valve spring will help to make it safe to rev. Edited by QUP29
I made just shy of 500kw at 6300 rim with a 6466 while still tuning top end. That block died a painful death, along with my wallet. The 6466 at 35+ pound should see 600+ on a well built stroker with a good head. I love good head.
like this guy says... Expensive lesson, I'm not risking it as its taken me over 1yr already!
I like the look of that graph. It basically proves my goal of 24lb +E85 will produce 550kw on a soft tune with my 6466.
On the stroker/rev topic. The full counterweight 90mm crank engine I have now feels way smoother than the modified 87mm stroke RB30 crank I ran in the previous engine.
The limit for most motors these days is what rod bolts are used. Piston metallurgy/forging and designs are being proven to 11,000 rpm on short stroke engine, however you need to look at the piston acceleration rates from TDC of an RB26 vs RB3X engines to see the difference on engine stresses. From memory, 8000 in my motor is close to 10000 in a 2.6. Longer rod engines have more mass swinging around too, which puts more loads on the rod bearing and bolts at higher RPM. (Correction) Less of a factor for the 2.9lt and less crowd though.
Beyond revs though is when your cylinder pressures start causing issues like lifting the head (stretching head studs), grinding rod bearing/journal contact due to compression of the lubricating oil film, and pushing the journals out of round for the really insane power levels. When you think about it, it is these last few things that make the 2J the stronger performer as the big power engine typically run 1/2" 625 head studs and the bottom ends are like a diesel engine.
Edited by GTRNUR
Your setup will be next level again to mine
A balanced stock crank will take far more than what most believe.
RIPs is turning standard factory RB30 cranks to over 10,000RPM and holding well over 1200+Hp reliably.
Similar reports with factory RB26 cranks.
The biggest limitation when using aftermarket forged rods and pistons is the rod bolts and pins used, from there the distortion of the bores is a major player, thats why people use part grout fills, most block cracking between cylinders 3 and 4 is from the front diff forces on launch going through the block.
How many have seen a RB crank that was crack tested actually snap?
And if so was it the crank material strength itself that caused it? Think about it......
  • Like 1
The front diff theory interests me, has anyone got proof or is it just a theory? Also does it apply to launches or cornering? Stock or aftermarket diffs...
I've seen a few RB30's cranks snap so they are not infallible, I know RB26 cranks are often unusable second hand because they are bent as well
Opinions on a 6466 w/ .84 TS on a built 2.6 with 272/272 10.2mm lift cams?
I have poured through this thread, and as such was leaning towards the 6262 or even considered the 6062 Gen2 thats just been released - but my engine builder is telling me the 6466 is 100% the go
I trust the workshop, but just want to double check other's results; dont want something that comes on at 5k or later.. id rather it come on hard at 4.2-4.5k rpm
Its concerning seeing people say a 6466 outflows a T51R
Edited by ohno1
with 272 cams and a 6466 on a 2.6L i'd be surprised if it comes on before 5k RPM but I have nothing really to base that on. Hopefully someone can weigh in.
edit: it would be and absolute weapon on boost though
Edited by Blackkers
Depends on the engine build, max RPM, fuel used, and purpose of the car - but I would look into the 6062 Gen2 for a street 2.6L. Rated at 750HP, the 6262 is 705HP [edited], 6266 is 800HP, and the 6466 is 900HP. I wish precision published compressor maps...It would make it easier to help pick a turbo that matches your goals.
FYI I went with BW 8374 EFR and divided internal wastegated .92 housing and I'm on a stroker 2.75L with milder cams for a better powerband for the street. I'll have dyno information soon, but if you search some of my threads I posted some 2.6L vs. 2.75L stroker match-bot (BW's turbo selection software) potential power graphs to show what the turbos do differently on these engines. If only we could compare them to the precisions.
http://www.precisionturbo.net/Street-and-Race/ss/600-800HP/details/Street-and-Race-Turbocharger---GEN2-PT6062-CEA%C2%AE/582
I would look into the 6062 Gen2 for a street 2.6L. Rated at 750HP, the 6262 is 800HP, and the 6466 is 900HP.
Interestingly the 6262 is actually rated at a lower power figure than the 6062: http://www.precisionturbo.net/Street-and-Race/ss/600-800HP/2
My apologies. You are correct about the 6262. Gen 2 added a lot of power. I edited my response. Thanks.
6266 would be my choice.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
