bigmikespec, just want some advice from an expert.. wat are the pros n con of having and not having the surge cover for "my" application on this turbo?
i want to run about 25-30 psi on the street on e85 and keep winding it up for race til it tapers off the power/boost curve...
If you are running a 3L definitely go it to avoid surge issues. 2.5L I'm not sure, you might get away with it, anyone got any first hand advice?
Originally Posted by KenHenderson
Craig, that made me laugh out loud, bud. Had some base timing map issues which we have gotten on top of. Then, we had a bit of surge to deal with. I was hoping I wouldn't have to purchase an anti-surge cover but I did. The first one was the wrong size, so I had to order a second one and I think they got it right this time. If these cars teach you anything, it's patience....
Every 6766 should have the anti surge cover!! The turbine wheel is too damn efficient. Put a back pressure guage on it and you will see.
THIS IS A POST FROM THE SUPRA FORUM BY SOUND PERFORMANCE WHO HAS TESTED A FEW ON SUPRA'S..
Edited by Ryan1200
Not necessarily; if there is low exhaust manifold back pressure in relation to boost pressure then the turbine wheel is able to utilise more exhaust gases to spin rather than the gases just build up and create back pressure.
True but if the wheel is just smaller then it is going to spin up faster anyway, so you could half the size, make back pressure ridiculous and it would spin up about 10x faster. That's why I don't really get why it is a factor in how much it is going to surge, surge is usually just too much compressor flow for the motor at x rpm.
What do you mean back pressure gauge, as in exhaust side pressure?
I agree rolls it's a bit of unusual statement to make in that context.. Maybe they have done back to back testing of the exhaust wheels and found for a given boost pressure the back pressure is much lower and spools much faster.. Who knows..
Hey gentz,
Ive been meaning to pump my mods into my motor for a while now,
BUT I keep going around in circles :(
Ive got an R34 GTR with a standard motor (stock bottom end RB26) - GTR is currently equiped with a full exhaust (which I will need to change as current setup is @ 2.5inch dump and 3 inch outlet to catback) AND a ARC custom air filter (panel).
I was either going to put in 2860-9's (twins) or now considering putting in PT 6262 BB.
- With the -9's (ill hit anywhere b/w 330kwatw to 350kw on pump fuel, 380kw+ on E85) - with support mods ofcourse (refer below)
- With the 6262 (ill hit anywhere b/w 380kwatw on pump fuel, and 420+kwatw on E85) - with support mods ofcourse (refer below)
The question IS, is running massive amounts of boost on the 6262 to produce 400kwatw+ viable on a stock motor (Im trying to avoid building the motor which has approx 50K km on it - due to extra $ required for rods, pistons etc..)
Support mods:
- Need to change the exhaust anyway to open up top end (will get 3.5 to 4 inch turbo/dump back regardless of which option)
- Already got: Haltech Platinum Pro, Tomei Adjustable Cam Gears
- Need to get: 1000cc ID Injectors, twin fuel setup + regulator, fuel rail to match injector bore, Tomei 260 camshafts (single turbo option) + Manifold + Gate, e85 equipment (sensors)
Those are the rough mods, above figures have been confirmed by Powertune in Fairfield. Though I would like to get feedback from anyone who has previously ran MASSIVE amounts of boost on these PT's on stock motor and how they are holding up (preferably on RB26's).
Thanks.
Faiz-
If you want to run 400kw on a stock motor reliably you will almost certainly want to run exhaust temp sensors for tuning and trim each cylinder individually, or just run it massively rich and be conservative of timing. Any detonation at that level will kill it pretty quick smart.
How good is your tuner?
Thanks for your feedback Rolls,
The tuner would be PowerTune (who have posted up a few posts/comments in previous pages).
They are most likely going to tune feeding of the sensors currently in my GTR (i.e. no new sensors going in apart from increased boost rating sensor and ethanol sensor for e85).
i would strongly advise you to get your tune checked out after to ensure everything is okay.
had my car done twice there only to find issues with the tune afterwards and ended up costing me more money in the end to fix up his mistakes.
You sound fairly switched on so I wont delve into massive detail regarding supporting mods, just search long and hard and make sure you have every supporting mod possible before chasing your power goals.
Two things I want to touch on and a recommendation:
2860 -9s will NOT make 330-350 on pump and 380+ on E85. They will make 300-330 on pump and anyones guess on E85 (quite possibly the 350 mark).
The precisions will want a lot of boost and you are risking your factory motor in the event of a minor fauxpas. For 400kw you will want to look at a 3788R, it is the replacement for 35Rish spool and more than T04Z power. You must run it in its twin scroll form.
Please read the 'who has 400kw' thread, it is the definitive answer to your questions.
Hey gentz,
Support mods:
Thanks.
Faiz-
Stay away from the Precision turbo option...
Keep it twin low mounts, with good pipe work and exhaust. 400rwkw cam be had around 24psi with a set of 10cm t517z trust turbo's with good response for the power.
Cheers
Justin
Scott, a Precision will be no lazier than what you suggested with more power capability, so long as you have the correct sized turbine housing
At a lazy 20psi? Please show evidence to support.
The 3788 gets up and boogies long before 30psi
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
