6 hours ago, Buraz said:
What's everyone's results with 6262 precision??
My is out of puff at just under 440kw and 26 psi on a 2.8l stroker
Mine has gone 560kw at the hubs. 440kw sounds significantly lower regardless of the dyno. Got a graph? Any restrictions?
Ahhh okay!! That's a big difference for sure. No restrictions whatsoever, it's a split pulse 6 boost and twin gates too. 17.5psi springs!!
Car hammers no doubt about it and I'm more than happy. Just thought I'd share my results with you guys and see other results
Oh wow that's a massive difference!! Is it same rear housing as mine?? After talking to a few people now, this thing is only a tiny turbo and tell me it's about right.
But yours is an unbelievable result. Still a 2.6?
  • 5 weeks later...
Mine should be hitting the dyno next week hopefully
previous tune was 645kw at 34psi with a 7175 gt42 on a hks 2.8
few changes since last tune such as 100mm plazmaman cooler and turbo1 custom twin scroll manifold with twin 38mm tial gates,
should come on nicer now then it did with the old greddy stainless manifold
  • Like 2
  • 1 month later...
How did it go?
I am quite interested to see how much difference a manifold makes.
I have a 6766 on a T88 Greddy manifold and have access to a 6 boost if the need arises. The car makes 460 odd rwkw @30psi on Unigroups dyno and traps 138mph but I still want more.
Have been told I should have gone the 6466 as its better suited to an RB26
Edited by ido09s
On 26/06/2017 at 11:22 PM, SimonR32 said:
The 6262 sillyness is never ending... New cams just got the most power and torque it's ever made
Lol what..
760 awhp on a turbo rated to 705hp.. not questioning your results but that is going to be overspeeding by like 30%
Very impressive that it's still happy pushed that hard. I'm interested in your exhaust back pressure and compressor outlet temp numbers.
Dynapack hubber gives a possible 5-10% inflated reading.. However simons back to back results with his setup and different cam combos are awesome and the car speaks for itself performance wise..
Its unfortunate that the next time its dynoed it wont be a true back to back unless you can sweet talk sean and he has access to the dyno still
Edited by azzada1
6 hours ago, burn4005 said:
Lol what..
Technically it's rear hub hp, not awhp. I don't think they have an overspeed (it's not an EFR after all)
Turning the dyno on SAE correction it shows up 797hp so god knows how much it's making at the flywheel but definitely more than the turbo is rated at. Never measured backpressure in exhaust but air temps after the intercooler are more than reasonable
its frustrating that no compressor maps are available for precisions because a turbo compressor power rating is usually based on an efficiency below 58% or even the stonewall flow (flow choke) of the compressor. this is the speed that part of the assembly reaches sonic speed and flow basically cannot be increased any further by spinning it faster or altering the downstream pressure. thats why the choke line is vertical in a compressor map. (although note that maps from garret state efficiency below 58% is the end of their displayed map, and they consider that point "overspeeding") It's not necessarily when it wants to fall apart, but the efficiency falls over and then finally the compressor won't flow any more due to sonic shock waves inside the compressor inlet or volute causing a choked flow condition.
its interesting that the Precisions seem to be happy well past the flow the manufacturer rates the compressor for. whereas Borg Warner made their turbines strong enough to cope with the choke speed of the compressor they paired it with and not much more as its outside the design parameters.
Edited by burn4005
  • Like 1
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
