10 hours ago, Griffin said:
Is that comparable to efr7670  /gt3576 ?
Impeller sizing on the PTE 5862 is very similar to the EFR 7670.
GTX 3576 runs a smaller turbine.
You'd think "broadly" comparable units, but they will all perform a little differently whether in-gear response, max flow, or boost recovery on gear changes.  Housing options in all cases would make a huge difference on those performance measures.
I'll be watching for results/impressions on the 5862.  V band turbine inlet, very nice :)
10 minutes ago, SiR_RB said:
Precision just released a new turbo model at sema,
7275 gen2, hopefuly start seeing some results shortly
At the 1000+hp mark, going to need something to stop it sucking the seagulls in!!
What application do you reckon Michael? - Strap one to a GTR and go Flying 500 at WTAC 2018, Snowy 1000 etc?
  • 3 months later...
4 minutes ago, SimonR32 said:
6262 still going strong. Makes very similar power on Mainline and Dynapack
Bloody hell.  Mainline hub I'm assuming?
Either way, huge result - I know this might be a silly question and I don't mean to be a dick by asking it but I'm just interested in knowing your thoughts... are you 100% sure this isn't a 6266?  There are plenty of people making less than this with 6266s and even 6466s :O
Yep, Mainline hub... First time using it, cool bit of kit and very consistent.
Funny you should ask (and I'm not insulted), I just mentioned to my mate who does a lot of work on the car yesterday how I wonder if somehow they managed to chuck a 6262 sticker on a bigger turbo. It's rated at 705hp but has done 766hp on a Dynapack with the correct correction and now 771hp on a Mainline hub. So god knows... In saying that I can't see it really being any bigger because it's making 15psi by under 4000rpm on the road in 1:1 ratio.
1 hour ago, azzada1 said:
Was that at the dyno day simon or private tune? I recall a softer ramp rate being talked about to help a certain au for the dyno day so just curious.. excellent result for the 62mm either way
Just did it yesterday, funnily enough a Falcon with 1100hp had just come off with a ramp rate that made my car sound like it was in 1st gear. We extended the ramp rate to a much more appropriate level
  • Like 1
Glad you got where I was coming from - was definitely not trying to be a hater or anything, just thinking through everything and I was fairly sure there was a decent chance the same thought process may have gone through your head too.
I was pretty sure you'd mentioned the spool was pretty decent and that definitely seems good considering the kind of spool vs power that people used to put up with.  This is a .84a/r hotside eh?  What diff ratio do you have?
Here is a 4.3x drive ratio in 4th gear doing a similar pull with a 1.00a/r 6466 with purely wastegate spring boost control at 1bar (so 1bar happens later than it might with electronic boost targetting an appropriate boost level) and considering how much bigger it should be than a .84 6262 it doesn't necessarily look THAT much laggier.
Could look at it that it's time for a 6466? ;)  You can see in the preview shot that it's already touching 10psi by 4000rpm and swinging up hard before the gate cracks
Edited by Lithium
0.84 and 4.11
Looking at logs I get 10psi in 1st at 4200 and 2nd at 3800
I've got a 15psi spring in my gate so I can potentially turn off my Mac valve and do a very similar run to that but on first looks it's a fair bit laggier. Assume it's a 2.6L?
Edited by SimonR32
7 minutes ago, SimonR32 said:
I've got a 15psi spring in my gate so I can potentially do a very similar run to that but on first looks it's a fair bit laggier
That'd be interesting for academia's sake but I believe you - there definitely should be a fair difference between the 1.00 6466 and the .84 6262 :)
It's a hard result to argue with, nice work!
Will grab some logs tonight. Because of the PPG 6 speed mine will sit almost dead inbetween between 4th and 5th compared to 4th in 4.3 so I'll do both and post average.
Should be interesting on weekend at Racewars, have 1000m run and I'm guessing I'll pick up a lot of speed from the sequential box. Best guess is around the 295km/hr region
That dyno run puts a smile on your face, i watched it several times lol, what boost was that at?
Its funny how precision rate the power of the turbos, when i spoke with them they said compressor maps cost too much to produce so they use real world figures.
I went through the process with them and they spec the 5862 for my car which they rate at 700hp. Obviously uses the same size turbine as the 6262 but has a smaller 58-76mm compressor instead of 62-82mm.
Had been hoping to have mine together by now but its still a little way off, hopefully soon though
300rpm better in the shorter 4th and more like 500-600rpm better in the longer 5th. From experience that would make a big difference to driveability.
10 hours ago, SimonR32 said:
Video of the run, about 8 sec by the looks
20180228_165754_1.mp4
Sounds yummy :) Great result!
Where are you getting it tuned these days? Need to find somewhere decent to go once I finish building my house and get my car back from storage.
3 hours ago, NEO25T said:
That was the turbo i picked until precision steered me to the 5862.
There was a 4 door r34 in the for sale section with the 6062 recently 407kw e85 25psi
Found it ? it even came off the same dyno as mine
  • Like 1
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
