On 01/03/2018 at 12:20 PM, SimonR32 said:
Should be interesting on weekend at Racewars, have 1000m run and I'm guessing I'll pick up a lot of speed from the sequential box. Best guess is around the 295km/hr region
Only got to 291km/hr but with the 30-40km/hr headwind I'm going to say I probably would have gone over the 295 that I expected. Got a very fast ET as well considering it was on AD08R street tyres on an unprepped airport runway.
Fastest pass here being a 18.106 @ 290.8km/hr with a half mile of 15.672 @ 180mph. The quarter mile was logged via GPS at a 10.2 @ 144.1mph
Edited by SimonR32
  • Like 2
Was not dissapointed with the stock block warriors! How your car consistently beats all of the big hp pretty looking ozzy park workshop builds is beyond me haha, those quarter figures would surely improve on a preped track yes?
  • Like 1
Would expect radials and motorplex to be a bit faster but who knows... I may get off my ass one day but need at least 18s to clear brakes
Why would it shock you mate? you pretty much summed up most workshop cars in your reply. They supposedly punch out big hp on a dyno but the track is a different story.... online warriors love dyno figures lol
  • Like 3
What size oil drain do you guys use?
Precision say minimum -10 which was supplied with the kit i got but after looking at the drain size at the base of the turbo it seems too small.
I didnt measure the factory turbo drain but from memory (which is terrible) it would be closer to -12.
Is this a case of bigger is better or will -10 be fine.
20180313_133413_resized_1.jpg.b067d59f8183c41550ec4abf2e9768af.jpg20180313_133823_resized(1).jpg.077e37861967d8349e37faa3fa342514.jpg
2 hours ago, burn4005 said:
i wouldn't worry about the drain on a precision, most of the oil goes out through the shaft seals.
So I run one, know several others that run them for years with no issues. Every time I see issues with seals it always appears to be install error
5 minutes ago, SiR_RB said:
Bigger drain the better on precision’s
and no sharp bends or kinks
I can run -12 drain flange on the turbo then use a -12 braid hose with a 45 degree fitting on the top end with a 90 degree on the bottom going in to the block just in front of the engine mount. Hose should be almost straight with only a slight bend. Might might have another look to see if i can use a 45 bend in the bottom of hose too but not sure if ill have clearance.
3 minutes ago, azzada1 said:
I also use an earls inline oil filter for the feed.. and be careful you dont accidentally turn the oil restrictor when tightening the oil feed line
Ok cheers thanks guys ill keep an eye on that, i think the kit came with -4 feed and turbosmart filter
Alot of people dont run the filter and dont run into any other issues either, But lets not pretend precision hasn't had its fair share of complaints and quality control issues.. I fit the filter for my own piece of mind and ended up having issues with the first motor and filter saved turbo.. my drain doesnt have any fittings just the push lock -12 i think it was and a nice curve to the block with heat sleave over it to make it last..
Edited by azzada1
i guess it probably helps that i don't leave the oil in the car for much more than 1000klms as the car doesnt get driven a lot. Its extreme, but when it sits for 6 months at a time and runs E85 we prefer to just swap out the oil and oil filter.
NEO25 - its been a while since i worked on a Skyline but is there any way you can run the front oil drain from an RB26 on your engine? it would make the drain very easy to make up then
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
