  • 3 weeks later...
Where is the flex join Jez? Exhaust looks good other than that.
I have never used a flex join on my exhausts scotty. The dump pipes are very secure near the gearbox. Plus it will test out the 6boost manifolds strength :)
Mitcho im hoping for 400kw from mine and 350+ from the R34 with 5558.
The main thing im aiming for is response. Well as much as possible with a 400kw turbo. I will be tuning mine with stock cams for now. Then poncams, then when the headgasket pops i will look at variable intake cam and port work. I will be testing the bottom end on my 26. If it lets go i will worry about it then.
Brilliant attitude!
Hope it all goes well, they're both going to be flex fuel aren't they or is it just yours?
Edited by Mitcho_7
I always run a flex in the screamer pipe as the expansion between off gate and on causes the pipes to move too much. The gate pipes are cold then become white hot as the gate opens. (get a video of it on the dyno, its impressive.) It will most probably crack at the base where it joins the dump and load up the gates and manifold/studs like you said. Bugger removing it all for repairs to save the $20 a two inch flex costs.
Thanks Scotty i will look into them tomorrow. Is easily added onmy car but on the 34 the wastagate pipes is only 2 inches long and turns 90 degrees in the 2inches.
Have u seen any crack due to the reason stated?
Besides mine will be on gate more not haha. Dyno time then trailer to circuit.
Here's hoping you can crack a 10 mate, it will be a nice setup.
I have seen one crack a stainless manifold within an hour on the dyno. (that was with a venting screamer.) I also watched my exhaust grow longer by over 2 inches and glow red at the tip. I can just imagine the stresses on the tubing up the hot end.
That sounds pretty wild, bet Jez is glad you mentioned this prior to him getting them on the dyno
It isn't really an issue if you like pulling the parts back off to weld them but I bet its a job and a half to fit. I just did a split 6boob install and it was a pita, especially the gate position. I fabbed it all in the car though.
    • Por qué no los dos? Body colour red with black stripes down centre, onto bonnet and bootlid.
    • From my bolts, standard M8 with 1.25mm thread pitch (M8x1.25mm).    Length is 19mm under the head and has a captive 18mm OD flat washer.   20mm length from a bolt shop is what you'll be able to get.   Make sure they're zinc plated.    If you're concerned about strength, grade 8.8 will be more than enough. Original PN is 01121-04971.  Now discontinued according to Amayama but that's because it's one of the parts that's been captured by the Heritage program, which explains the ridiculous price.   New PN is 01121-RHR20: https://nismodirect.com/nismo-heritage-bolt-pin-hinge-hood-bnr32-nissan-skyline-gt-r-01121-rhr20-01121-04971/ About AUD33 converted from Yen in the above link but that's just one example. Interesting that the hinge-to-body bolts are still available non-heritage.....PN 08116-8161G around $2 each (amayama).    Same thread but 16mm long.
    • Well, if that filter was impeding fluid flow, then it could have similar effects to faulty solenoids. The TCU will register a fault when it does something (ie, changes the state of a solenoid) and does not detect the required result. If there are other causes that can make the same lack of result, then they will be indistinguishable to the expected cause for which the TCU has a code.
    • Yellowjackets, red ones, blue ones (other than Splitfire) have all been demonstrated to be unreliable on turbo engines. That unreliability can be anything from outright failure (ie, 4 out of a set of 6 working out of the box) to just not being strong enough for the task, on a boosted engine. Not enough of us care about NA engines to know whether that unreliability is an issue for the undemanding needs of an NA RB20. I should think though that the DIS-008 should fit the 20. There's not really any reason for the head/coil mounting area to be any different on those 2 Neos. I wouldn't be buying Splitfires, or any other old tech coilpack, for a car in this day and age though. I would buy modern pencil coils and do what needs to be done to adapt them to the loom. That's relatively trivial these days, with numerous kits for fitting R35, or Audi, or Yaris/Corolla coils.
    • Keen to see how much work is needed to get an abandoned Skyline going. My R32 has been sitting idle for three years or so but finally got some time to get it going again. (Also lurking SAU and trying to hit 10 posts so I can start my own intro thread with pics)
