Left it for now. Was up too 262kw at 5500rpm 14.5psi. Was just having a play tonight and good to hear it running.
Waiting on the new fuel system to arrive so we're ready for the eflex.
Surge tank and lines are on the way after ur very helpful input Matt. Cheers for letting us know about urs.
Fark im so keen to get mine on the dyno now.
Looks very similar to GT2871 results on a neo 25, I have a turbo that is highflowed with the same wheels that looks very similar to that graph though less power due to the restrictive rear housing.
http://imageshack.us/f/4/img20120517221202.jpg/
Be interesting to see how well this turbo performs when you finish the tune! Neos always seem to give fantastic results.
http://imageshack.us...0517221202.jpg/
Yeah.... Nah! It doesn't haha
Neo usually make a little less power actually because they are pingers
The few tuners I talked to seemed to think they always made more power as they seem to rev more, seen two results that seem to point that way, eg matt from nistunes r34 that makes 310rwkw on a 0.63 gt3071r with poncams on only 18psi, dyno sheet is on here from a reputable dyno/tuner, and then mine which is a highflowed rb20 turbo with the rb20 rear housing still that makes ~258kw on only 16psi
Edited by Rolls
On the same dyno for both?
Regardless from what i have seen, neo's seem to get a bit more compared to regular rb25det's with similar bolt ons.
Yep both on same dyno same tuner. Pete from nistune and the morpowa dyno in adelaide, he told me every neo he has done has gotten fantastic results compared to the r33 engine, "chalk and cheese" were his words from tuning multiple neo and r33 motors.
I also had identical everything just changed from r33 rb25det to a neo rb25det with the r33 intake, all the same sensors, hoses, literally everything the same just the block changed and went from ~236kw at 18psi to 258kw at 16psi.
Edited by Rolls
That's a solid improvement!
Is there any rewiring for sensors or the loom etc needed to put a neo rb25 in instead of an s2 33 rb25 or does just the ecu need to be changed?
The 34 looks like it will put up a good number, I think you'll shite 400kws in Jez
Im curious to see when this turbo maxes out.
I know Kurtis is now a power junkie but this thing is aimed at max response with strong top end. I have the goal set at 350+.
Time will tell with my one too. Its a 700hp turbo. But same again its main goal was response and 380+
He'll make it, i have faith! Its a 700hp turbo vs my 550hp turbo and i NEARLY made it, so you guys will make it for sure :D Cant wait to see, its sounding good!!!
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
