Isnt this turning out a little excessive for sub 400kw?
I wonder why it needs so much flow, le hmm.
Sorry mate
Didn't realize I was spending your money,
Flow is no longer in question Jez have spoken with e85 guys and they believe it's related to the fuel heating up to much second pump is to help with said issue
I think what he meant by excessive was its seems odd that your fuel system isnt coping as well as others have, I dont think he was talking about cost.
Eg some people are getting enough fuel flowing to make around 360kw on e85 using a single 044 intank with standard fuel lines and you are having to add a surge tank, bigger lines and another fuel pump. Granted I dont think they are going to be putting out quite as much power as you when your tune is finished and they werent running as much boost, but still.
Edited by Mitcho_7
Sorry mate
Sorry WHAT?
Dont be so defensive like im mocking your hard earnt layout. Good luck to you, I hope your stuff turns out well, I message Jez on the regular and get updates on how your cars coming along. The way you replied to that is almost offensive.
Mitch above is on the money. Im simply curious as to why its needing so much flow, and in a perfect world that could have lead to discussion about what other people have flowed with what setup. Who knows, maybe a few great minds would have joined in and helped troubleshoot so you can find out whats going on.
Spending my money, pff.
:no:
360kw with single pump is the limit.... Well 357 was the final SAFE number anyway
Standard fuel lines were all over and done with above 340ish.... I had to go bigger lines and modify the fuel tank hat...
:no:
This I was not aware of
GTR/GT-t = same last time i checked... Wonder how the GTR guys are getting 400rwkw+ through stock lines & E85 (with just a Nismo pump) :unsure:
I think its a lot to do with the fuel hat itself.... It was a restriction.... Hence the modification :)
355rwkw here on pump98 and single pump no restriction. and 335rwkw on eflex no restriction all stock lines and rail. in gtst.
Well i dont want to go dribbling shit without properly understanding it myself BUT on my car the fuel pressure was unsafe at 360kw, after the mods were done and it was rechecked the fuel pressure was spot on at 357kw so it was obviously a restriction...
My original post from page 30 said exactly that.
Then I edited it in fear of a flaming :P Thanks for putting it out there though, I knew I wasn't going mad.
Sydney is warmer than Mexico. We need stuff like 15 litre sumps and 3 fuel pumps. :woot:
Hahaha exactly.
Maybe this will make a few people scratch their heads.
hehe :)
I'm a bit behind on reading all threads at the moment. Too busy, so i tend to miss post replies where I usually see most even pre-edit :P
Nismo outflows a 044. Im hoping my single walbro 400 will be ok otherwise i will mount a 2nd pump in tank
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
