We have a GTR over here that runs on full 100% ethanol. Makes 630rwhp on a roller, gets the pure ethanol very cheap through a limited source.
Almost wouldn't start after sitting at the track on a cold night so not really a great recommendation haha
E100 isn't new, been there done that :)
An R34 with those K's though, never seen one in real life with that many k's on it!
You still haven't, it was a picture :ph34r: hehe
Its a good sign for the other 34's on the road though, shows they are well built!
Kurtis, the suspense is killing me already!
Oh come come now. You Daniels 34, tuned by Status - makes over 400 on E85 with just a Nismo :)
Exactly my point. 044 around 200lph. Nismo 246lph but i cant find specs for flow at higher psi which is where it counts
Well for a while I've suspected the Nismo pump to not be "as much" of an upgrade over a stock GT-R pump as many would believe.
It's simply the cheaper option so hence everyone goes down that road given a stocker is 10yrs old and offensively priced from Nissan
There are some numbers on a stock GT-R pump below (makes for some interesting reading).
http://www.stealth316.com/2-fuelpumpguide.htm
working in the boot of his car paid off today, AFR's are doing exactly what i wanted tonight. Just got back from a drive with it. went down to the servo to top up the $21 worth of EFLEX, racked up some sensible km's, think we are up to 50km just cruising around with a few squirts on 14psi low boost, and only 1 half throttle tyre fryer on high boost, got scared as midnight and tired, had a big day.
Maxed out at 367kw on 22psi, tried more boost with no gain, but very impressed as its all legal in the way of Catalytic converter and wastegate plumbed in, thing is a sleeper.
still got to finish the tune back from E67 down to 98 octane but atleast everything held together :D
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
