Very first pull on the dyno, well once i changed to a 7 bar map sensor. I used 16psi springs in my twin scroll manifold. But for some reason 22 is my low boost. Its a major job to get the wastegates off as i have plumbed them in and very little room to work around.
On this run i backed off at 6400rpm
Overlay shows my previous best with -7 copy twins.
Both on E72, both have same tyres etc etc. the e72 in the tank atm is 6 months old
How about some rpm scale love there Jez instead of road speed?
All looks promising so far - I bet you're happy!
I can try for u stevo but its only roller speed and i can input what rpm at a certain Speed if that makes sense. I mainly use it as a reference. Worst part is it doesnt save each time the dyno is on so i cant do comparo's on different days with rpm.
Gotta be happy with that jez
Very. Cant wait to push some timing into it. Think i might stop at 420ish kw. As stock engine and cams
Yeah that makes sense, fair enough.
When's more tuning going to happen?
Putting fresh fuel in for that?
Would be great for someone to do back to back testing on a range of these things. Eg 5557, 6262, 6466 etc all on the same engine, same dyno
I think I put a link in here a while back from some guys who did just that, albeit on a 3.4L jz
What twin scroll manifold and gate/s are you using for the precision Jez?
6 boost manifold twin tial 38mm gates. Custom dump and plumb back piping.
Stevo hoping to get the rest tuned on e70 sunday. See what boost i need for 420kw. Then wsid for a 1/4 mile run to see if she holds together
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
