4th gear stopping before limiter. I have alot of mechanical sympathy :)
Limiter is 8k. I like my stock rod bolts non stretched :D
Hmm. Something is up. 4th at 8000 RPM is 235 km/h and you're going to 190 ish km/h which is 6400 RPM. :S
Could the road speed on the dyno be wrong or something?
It's only my gay 4door gtt that needed so much fuel system work
But hey Can't complain with 367 @the wheels
At least your gay gtt runs ya kent :P stupid flex fuel!!
Nice result so far! Though to be fair I'm not sure if the PT6262 will really be showing its mettle yet, have you had any stock RB26 with a GT3582R on E85 on that dyno? That would make for a very interesting comparison
No i havent. This is the first single on rb26 on this dyno.
I wish i had a forged motor so i could run 35psi. I think it be close to 500kw
took it for a cruise to get some pizza. Without finishing the tune down low it drives very nicely. Below 3 very little boost. Above it picks up nicely.
So are the Precision turbos their own CHRAs or common with Garret. I am looking at either a FP73HTA with one of these housings but also considering a Precision turbo...but makes life easier it i can run one of these rear housings
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=TP&Product_Code=ATP-HSG-075&Category_Code=
Has anyone worked out the rpm vs speed yet..?
How fun would that turbo be on a 3lt
PT6266 would be more fun :D There are quite a lot of Supras running them, they seem like a pretty brutal all around setup.
Off topic, Jez u get the pic etc? I have the same issue as Kurtis :(
Hey buddy, yes i got the pic. Very dissapointing i was sort of hoping it was an odd issue with Kurtis's car, but if its happened on a different car with another workshops setup makes it very annoying. Hopefuly warranty wont be an issue.
Txt sent
How does the turbo sound when your up it Jez?
I've been told they are rather quiet compared to most singles...
On the dyno from in the car with headphones on i couldnt really tell. U can definately hear it spool up like a jet when inside the car but i havent been incar with a similar setup so cant compare.
No prob Jez , just put it onto mine and see what it will make :)
    • Hi guys looking for a r33 Gtst stock exhaust asap in Melbourne have $$ waiting thanks
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
