Congrats man !!!! New you could better the 11.0 time, first run with cold tyres was funny to see, crab walking lol
What was ur 60ft time and mph Jez?
My guess is 1.75sec on the 10.81 @ 131mph run
Edited by SimonR32
1.687 60 ft on the best run
Haha yeah Michael the first run was interesting. Crabbing 3rds haha.
I had to put it in RWD for the last run to do a burnout to get some heat into the tyres. Then turn the car off to engage 4wd. Still had wheelspin off the line.
Congrats to u too Michael. 11.3 good work. Its all in the tune though :D nothing to do with ur driving skills haha
Well done man.
Would have been a decent 60 footer. 1.6-1.7?
I was .1 second off a perfect guess lol!!
After giving it a belt, the lag between gears? Better than the little twins?
Good estimation thats for sure.
Not even the slightest bit of lag between gear changes.
I had to raise the limiter to 9k as it was a hard cut at 8k slowing me down in first gear.
Also i crossed the line at 8k on the limiter at 211kph
Were u on the 9k limiter in first when trying I get it out of the hole?
Didnt hit 9k limiter but made it alot better to throw the car off the line and change at 8.5k.
What size tyres do you?
Weird that most 4.11 cars do mid 220km/hr in 4th gear at 8000rpm
Honestly it probably was. Just after crossing the line. Makes sense.
Running 18x 10's with 245/35 kuhmo V70a tyres.
Hopefully will have a vid up soon from my chicks phone
What RPM were you launching from?
i have no idea honestly. Was watching the lights.sounded like around 6k
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
