Thanks mate!
Ron: the SR is good for about that 280-300kw mark. Its just about control factors. If on 98 a little ping will do a lot of pop at that level, but if tuned safely (like on E85) they are pretty OK.
For reference my 'built motor' is nothing but a refreshed stocker with forged pistons. Im reusing the crank and rods and aiming for a motor that will never see more than 350 even if I do go crazy in the long run. It will probably never see over 300 in reality.
Because the last tune was close to 430 RWKW. Different head and a few different mods I wanna see what these little things can do. They should crack 450 without too much trouble.
-5's aren't too bad, A Z32 at Unique Autosports just cracked 447rwkw on 21psi and pump fuel with them.
are you saying someone nearly cracked 600rwhp with -5's at 21psi ??
From what he's said he has 3" Intakes on the turbos but they are run of the mill -5's apart from that.
http://www.aus300zx....2&postcount=358
Edited by Super Drager
Thanks mate!
Should go a td06sl2 20g 8 cm but with billet compressor wheels
Transistient boost response will be better and get maybe 10kw more up top
Hypergear can get them or gtpumps or you can get kando to make one as kamak is making billet compressor wheels now and kando get there turbos from them
I think you'll find they're 2871R's or -10's from my conversations with John from Uas who is building on it.
Could have misunderstood though.
Nope, take a look at the thread i posted. GT2860-5's. There is a Z32 that was built with GT2871R's though, he put down 467rwkw.
Have you seen any results of any of the above turbos vs billet wheeled versions?
my PT6262 .84 TS will be arriving this week hopefully, should in interesting. I havnt seen anyones results on this forum using one with this setup (25/30 with vct).. should be neck breakingly responsive ;), and if it taps out too early, well.. only $285 for the 1.0 housing to be sent to replace the 84 and try again.
Eagerly waiting results as this was the same path I wanted to go down! :) Built motor? Is the 6262 Gunna be pushed hard mate?
Just had a result sent in from a SR20det customer made 282rwkws. That is our billet version, don't want to hijack the thread, check out dyno readings on my thread.
I have a billet 7175 (.94 single entry) on a single cam rb30. With a powerglide.
It's as responsive if not slightly better than a 35r (1.0x). Makes 549hp@28psi on e85. Trapped 138mph. Keen to feed it proper boost soon and see how it goes :)
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
