As has been said many times before, if you drive sedately like a normal vehicle for the last 1km or so there's no need to let the car idle when you're parked. Just don't thrash the thing before pulling up at your destination and you'll be fine.
okay im looking at getting a 6262 .82a/r Twin scroll with a matching 6boost manifold. Can anyone tell me about their experience with this setup i have not found any results with this turbo on a RB25. Im after getting about 500hp but need some headroom for further plans. iVe noticed a gtr doing this at about 20-24 P.S.I but rb26 and rb25 are a bit different. Any help will be appreciated.
http://www.skylinesaustralia.com/forums/topic/377634-gt35r-or-precision-6265-ballbearing/page__st__20
First post on the page, that guy says good things about it. Maybe PM him to see the housing size?
Thanks bro that's a Gtr though.I've noticed that not a lot of RB25 go with the 6262.what makes it harder is finding one with the twin scroll as I want to find out how much laggy it would be.
Bryce, I know from experience that the 6262 and GT35 are very, very similar in response. There is a back to back comparison from the US here: http://forums.nicoclub.com/highest-horsepower-rb25-stateside-t477938-40.html
Note the 6262 was running a larger housing (Tial) I don't the Tial v-band housings do anything extraordinary at all...
Also, PTE make a .84 T4 divided housing only.
Cheers,
PJ
Bryce, I know from experience that the 6262 and GT35 are very, very similar in response. There is a back to back comparison from the US here: http://forums.nicocl...t477938-40.html
Cheers,
PJ
yh i meant .84
might get the twin wastegate setup if the funds permit but if not will stick to a single W/G
so im set on a 6262 TS .84 aiming for 550hp and some headroom
Took my car for a quick spin today, was getting 1 bar in 3rd at about 4000rpm and just below 4000rpm in 4th.
That was running gate pressure of around 1bar (so not exactly optimal as it would be opening partially before then) and has not been tuned or cam gears played with yet! Pulls fairly well for only 15psi :)
That's a 6262 on a stock RB26 with drop in cams.
So far so good, can't wait to get some results from the dyno
Edited by SimonR32
Scott is right. T4 0.84 divided
I'll check at 3000rpm if I get a chance, it seemed to be ramping fairly quickly at 3500rpm
Whats the rest of the setup? rb26 yeah?
What piping and throttle body are you using? that would make a diff to if its short rb26 plenum runners.
Hey guys, see pics of my PTE 5558 0.63 plumbed up to my R34, injectors and tune coming this Monday, 98 fuel and as high boost as possible. I urged them for a safe 22psi but JEM says they mostly go 20psi on 98 fuel unless its a built engine?
Words of their salesman so I'm sure the tuner will give a slightly different perspective. Well fingers crossed and really hoping to crack 300rwkw - its on stock manifold btw.
Do you guys see issues with the way the pipes run (I think the 3" from pod is a funny angle), the weld quality looks top notch.. ;)
Edited by rondofj
looks good ronny!, be good to see how it goes, My big Pt cleared customs friday..bastards tried to stitch
me up...lol, ended up only paying gst on $1000 and payment for submitting form, so $178 extra...was $600 ish
intially as they tried to to tax me on $2500
cheers
darren
Edited by jet_r31
cheers
darren
which one did you get mate? I paid $1050 all up for turbo, 2X silicon joiners for turbo cold side with clamps and incl postage too. I didnt pay any duty haha
.., nah i paid it, because it got sent from a friends house in ohio, and she sent it without asking
and instead of writing nothing about it, the goose put turbo worth $2500 on the postage..customs picked it up straight away
I sent a letter explaining it was a second hand journal bearing 7675 ..that i only paid $1050 dollars for it..lol, and that i can buy them of ebay for $1500 delivered from the u.s
any day of the week, so why would i pay $2500, so they just charged me GSt on $1050..i was happy with that.
cheers
darren
cheers
darren
Lol @goose hahaha cracked me up..I got the seller to put 850 on the sticker so paid nothing in tax
    • Regardless, its peace of mind swapping the factory twins for something else. Personally if it was me: Link G4X Additional sensors for engine protection Twins Oil pump mods(maybe throw extension to sump) injectors/Pump Clutch Exhaust Oil Cooler Good pads/suspension Should be good for 3-350kw depending. Granted thats closer to 15k but still.
    • I think you are over thinking it again
    • My R33 never ran more than stock boost but it was unclear whether the turbos would last. Maybe OP's car is less of a question mark but for my stock turbos had over 175k km on them + 25 years of use. That's a very long time to hope nobody has ever accidentally put physical shock through them, no debris in the exhaust gas stream, no boost leaks that could cause the compressor to spin faster than it otherwise should, no oil coking in the journals, no wear scars for any reason, etc. You could pull the turbos and disassemble to inspect/overhaul as needed but for that kind of effort you may as well replace the ceramic turbine with something that can take a bit more abuse no matter what you find in there. Stock boost ceramic turbos really don't make that much power either.
    • A Pillar forward?   The part above I was just looking at was the reo bar, I'd replace it, UNLESS the panel beater is GOOD. From your early photos, it did look like the chassis might be tweaked, or at the very least there was tweaks in radiator support. I'd personally do a new / second hand unmolested reo bar, and drill it, only so I know underneath the pretty painted front bar, there's not a mess of other metal that's been hit and smacked.
    • Yes no yes. Pineapple rings do do a certain amount of subframe "locking up", in that they do add some resistance to lateral movements. But the primary reason they exist is to alter the driveline angle. Depending on how you install them you can either increase or decrease rear traction __ a little bit __ by changing the angle of the lower control arms relative to the car/pinion angle. The thing is, given what they are, how and where they are installed, their lack of engagement with anything in particular, there's a limit to how much benefit they can offer. The GKTech collars put metal into the space in the stock format bushes, thereby limiting how much give they have. The rubber is still there to take up some force, albeit perhaps preloaded a little by having some extra metal jammed up into it, but the increase in stiffness comes from making it so that the stock format bush can't deflect that large bit of rubber over into the space adjacent to it, in any direction. Top AND bottom. Which the pineapples certainly do not do. As I said in my other thread - I'm convinced.
