i have seen dyno sheets floating around which are probably in this post somewhere anyway - which show the difference in the response between, 6266, 6466,6766 being about 500rpm on a 3.4L ...
I have even emailed precision directly who have confirmed that it would be about 300-500rpm on a 3L
Thanks. Have seen it but not sure on that one. I think the 6262 is the one.
Yeah just give it a ago they are pretty interchangable apparently.
I went for the 6466 as I figure if worst case it was 600-700 difference in response from the 62-64 - something i doubt im really going to notice when its on an engine which will snap the rpm needle within a matter of seconds anyway - which is worth it considering the top end gains!
Is anyone running a 6266? How much lag are we talking about between the 6262 and the 6266? Can't decide on what to go for. If the RPM difference is negligble i'd be more inclined to go with the 6266 for the potential to make more power at a later date. (Both turbos with 0.84 Twin scroll)
Looking to make 400kw on a RB26 with all the basic mods. Will a 6262 make that power on 98pump fuel (say no more than 25psi)? I've seen that SimonR32 made 420 but that was on flexfuel.
Edited by RRP1
I actually made 450kw and trust me there is plenty more in it but I ran out of fuel pump.
I wouldnt be suprised to see another 30-40kw if I ran 25psi but as you said that is on e85.
6262 is a nice balance for decent power and not too much lag. I was tossing up between it and the 6266 and went the smaller. I think I made the right decision
Edited by SimonR32
no probs....i dont think there will be too much difference to be honest but i cant find the wheel sizes for the 6266
6262 is as below tho
Compressor-
Wheel Inducer: 62mm
Wheel Exducer: 82mm
Turbine Wheel -
Wheel Inducer: 72mm
Wheel Exducer: 62mm
i think i did read that the exducer of the 66 was slightly bigger but dont quote me
PTE 6466 - for anyone looking at this turbo.
Compressor Wheel 2.535" (64.39mm) inducer / 3.410" (86.61mm) exducer
Turbine Wheel 2.920" (74.17mm) inducer / 2.600" (66.00mm) exduce
HKS T04Z:
Compressor Wheel:
T04R/T04Z, Inducer 66.7mm, Exducer 84mm.
Turbine:
T04 P trim, Inducer 74.2mm, Exducer 64.6mm
Garrett GT3540R/GT3582R/GT35R:
Compressor Wheel:
56 trim GT40, Inducer 61.2mm, Exducer 82mm.
Turbine:
84 trim GT35, Inducer 68mm, Exducer 62mm,
for comparison..
Alot of guys are running the 6466 in favour of the 6266 in the states and report no change in spool/response but more power up top.. Would like to see some results on RB26 though.
Edited by RRP1
So how do people reckon a PT6466 would compare with a Garrett T04Z in overall performance? Would you be able to use the Precision in the Garrett's place and expect to make similar (or better) power on pump gas on a suitably built engine?
HKS T04Z:
Compressor Wheel:
Turbine:
Compressor Wheel:
Turbine:
for comparison..
6466 only comes in ball bearing tho which is all good but cant justify the extra cash for it
i dont think you can go wrong the PTE to be honest
Should make plenty more power without being too much laggier from what I have seen
Thats interesting, I'd have hoped for it to be at least as responsive!
Well my 6262 is better than my old T04Z but not the miracle that some would lead you to believe. The 6466 is a fair wack bigger (195hp rated), I doubt you would be getting that for nothing :)
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
