Precision Billet Turbos
Pretty much my dilemma as I was saying on the last page, going off the dyno sheet on the 3.4L there isn't much in it and the top end gains are great.
From going by there website the 6262 was the first of that sort of series then they did the 6266 which is a touch bigger, then the 6766 which is bigger then a To4z then recently the 6466 which sits midway between 6266 and 6766.
And yeah I highly doubt you would notice the 600-700rpm difference (as quoted by a precision rep i spoke to) between a 6262 and a 6466. You literally wouldn't pick it by driving it I think you would only notice on a dyno graph as above considering how long it takes to jump 500rpm at the 4000rpmk mark on even a stock RB
Are you joking? 600-700rpm is a huge difference. That's about the difference between the T88 that was on my car and the 6262 I now have.
The T88 was horrible and I mean horrible on the street and even worse at the track while the 6262 is a great little zippy thing.
Well my 6262 is better than my old T04Z but not the miracle that some would lead you to believe. The 6466 is a fair wack bigger (195hp rated), I doubt you would be getting that for nothing :)
That's why I thought I'd ask, people have claimed that the PT6262 spools better than the GT3582R which sounds unlikely but who knows. The PT6466 is not far different in measurements to the T04Z and there is no lb/min rating for them - though Precision rate them at 900hp. Does that mean they can be used in place of a T51R Kai on a pump gas setup for someone looking for a bit more power with the same or less lag? It seems unlikely to me.... there isn't even any reason for me to have confidence that they'd make more on pump gas than a T04Z.
I'm trying to determine the place of the larger Precision turbos when huge boost and E85 isn't involved.
the wheel sizes im camparison are a huge difference between the too aswell which is why i find it hard to believe that they are rating it that much laggier between the 62 and 64mm turbines
From my experience with my own engine, a certain boost pressure = very similar power level provided the turbo is still within its capabilities. When a turbo start to roll over of course the power gains decrease per psi. As you'd know pump fuel and 900hp are a mismatch (on a small engine anyway), as you will never be able to put the boost in that is required to get it in the zone.
I would certainly place my bets in saying that a 6466 will outspool a T51 donkey (sorry to all my friends who I have offended in saying that :devil: )
The test that Sound performance is a good example how different the 3 Precisions react even though they have identical exhaust wheels.
Yep, same findings here too - well except for 900hp on pump fuel, I know a few mad men who have managed 900hp (flywheel estimated at least) on pump gas on RBs. Big turbos, lots of rpm and head porting involved of course.
Hahahaha yeah you would REALLY hope it would outspool a T51R, though I would be extremely surprised if you could squeeze the same pump gas numbers out of an engine capable of it from a 6466 as a T51R.... and to be fair, would be interesting to see if the peak power numbers on race fuel would be comparable too. I wonder how those power ratings were determined...
Some of these tests make me really wish I had a dyno. A lot of these tests people refuse to touch timing etc to keep things equal, and I honestly haven't done enough first hand dyno tuning with like setups to ascertain whether this is a fair way of comparing or not. Will optimal timing be the same at the same load and rpm for every different turbo setup?
Ive also always been wary of bolt on bolt off tests that crop up. Surely charge temp and turbine efficiency alone would leave a few degrees in the lurch between models.. Otherwise what is the point of spending an absolute packet on tuning? Time to jet up our cabys and change the chip in our MSD.
Get yourself a dyno Lith :) Once you have a place to sit and tune which belongs to you the customers will start lining up.
Here are some more results from this Saturday on the dyno. We were aiming for 35psi on the next hit, unfortunately the idle speed control screw of all things decided to unwind itself. It was already 9pm when we sorted it out so had to cut it short, but I am very confident in saying that we would have seen 1150whp.
Pretty amazing how linear the power curve is since it is making drag engine power. Rev limit is set to 9500rpm.
Went for a drive yesterday (to get it licenced) and did some 4th gear flat road pulls from around 3000rpm, getting 1 bar at 3700-3800rpm which is probably a few hundred rpm better than my old GTR with a T04Z with similar top end power capability. Makes for a savage car on the road, pulls long and hard through the gears and is an absolute bullet.
Going to go back on the dyno after I sort out a second 044 and run it up again holding 1.6bar through the revs, should go 650hp (485kw) fairly easily by the looks :)
nice...
can you post a sheet? couldnt really see the figures prop.
where was it coming on boost?
guys, i seem to be blowing out a bit of blue smoke on hard acceleration and shortly after
just wondering what could cause this
i am running -4 feed as per precision's recommendations and a hardline drain to -12 hose to the block
i thought precisions had in built restrictors or do i need to put one in??
Is yours BB or JB? And are you certain its oil smoke?
Check cooler plumbing and plugs for signs of oil leaking from the compressor side. Most leaky PT threads I have seen are comp side and the leak can be seen on idle with the pipes off.
  • 3 weeks later...
    • So next year I am looking at upgrading from my VE SS bomadore ute to something more refined.  I wanted to stick with a V8 but not anything German or Australian, either a coupe or a sedan. So if I wanted anything newish that limited my options to either the Lexus RCF which I quite like. But with the price they demand and a kid on the way a 2 door coupe is probably not going to be the best idea. The next best thing would be the ISF but the newest models are 2014 and commanding over 60k and even the older 2008 models in ok condition starting around 35k is kind of bullshit. So I figured if I could not have the noise I could perhaps make do with easy power. Enter the infinity Q50 or Skyline equivalent. The price difference between the 300 and 400hp models seems a bit crazy. Right now there is 300hp Q50 one on carsales from a dealer with 61km for 27k drive away. If I wanted to get a 400hp Red or 400R car the prices seem to start at 43k From my limited research it seems that the only differences are that the 400r/Red Red runs more boost and a more aggressive tune. There are are turbine speed sensors on the turbos. Has 2 pumps for the water to air intercooler. Runs an engine oil cooler. I'm guessing that the exterior trims might look a little more sporty as well. I had a lazy look for upgrades to bridge the gap on z1motorsports They have kits that upgrade the water to air heat exchanger as well as the coolant pump which should give a non Red/400r better intercooling temps than the stock Red/400r. I added an engine oil cooler with a thermostat as well to try and make things as close as possible. Obviously the ECU is going to need a tickle. Having not done much in the way of research they also sell a ECU flashing tool with pre loaded tunes that are supposed to boost the non Red/400R by 100hp which adds 1k USD to the cost. The total cost of the parts @ the current time including shipping and taxes worked out to be $4350 AUD. Personally I would rather get the car tuned on a dyno which would probably add more cost Assuming the worst that you got a workshop to install the new parts I would guess no more than 5 hours would be required in the worst case @ 5 x $150 per hour = $750 So the total cost could be around $5100 So for easy number 5k + 27K = 32k I guess that would leave some change left over to swap out the open diff and fit a LSD Any thoughts?
    • Right, not sure why I thought it to be a lean spike. It might be fixable with modern card-style hot film MAFs which have some design features to avoid counting reversion flow but I've never tried it myself.
    • I did not realise this, I'll contribute more and earn my stripes and retry later.
    • I'm only going to hassle you for posting links to images. It's against my policy to click links that could be some nasty payload. Sadly, you need to make 9 more posts before you can just stick the images directly in a post, unless @PranK sees this and bends the rule for you.
    • Hello,new to the group, I bought a R32 from auction recently, wondering if anyone knows the cars history, seems to have the usual go fast bits on it, plan is to do an engine swap- add 2 extra cylinders and 1 extra turbo. https://www.dropbox.com/scl/fi/i4rjmlzubjbwjtguh6f4s/IMG20241011140744.jpg?rlkey=q0lumm251377vknbqktfwrycq&st=7scvwx4e&dl=0 https://www.dropbox.com/scl/fi/ro24qmwzlczzlfsr4y05x/Screenshot_2024-10-10-10-49-23-90_9a2f5bb2149dae94cd1e190effc09b33.jpg?rlkey=oyguh26ttshlf04ccp48odf4v&st=xloae97b&dl=0   New to forums and posting pics, if links don't work, take it easy on me, 42yrs old and I tune carburettors!!
