LOL Simon, that car is fast. Sky is also blue, but I just wanted to say it.
How do you get your freaking helmet to fit? Im only 180cm and a helmet like yours in my S14 does nothing but trade colour schemes with my hood lining.
Is the Bride mounted super low or your shorter than me or what? It shits me to tears, I need to lay my seat back heaps and slide around like a moron at the track lol
haha
Response wise the 6262 really impressed me over the weekend. Did lots of roll ons from 60km/hr (just under 4000rpm in 2nd gear) and every time it was cracking gate almost instantly on 100% throttle application.
Check out this run with an XR6 Turbo that runs a 11.9 at 120mph at the drags. I hit the throttle at the big bollards and it is straight on gate (24psi)
Is it me or are these Precision turbo's very quiet on song? Every video I have seen they are quiet as!
Bulldog run Simon. Congrats :D
The mid frames hardly make any noise, when you're cruising they make a multi-pitched noise though, you can notice it at night.
The larger frames like my 7175 "almost" sounds like a T51R.
What power was the r32 it making in this video?
It was making 600hp on a hub dyno, we tried to tune it on a roller with about 4psi more boost but it just wheelspun at 560rwhp,
Best guess would be 650hp at the wheels
Edited by SimonR32
Here's an update for the RB26 VN at the track. Still a bit off its potential on this power (910hp at the wheels on 25 psi), but it's getting there! Weighs 3315lb with driver, has steel, glass and a heavy interior.
I'm sure you'll enjoy the sound.
Would weigh 3314lb after losing that side skirt at the start.
Amazing machine
Here is an insane result for an RB26, I can't get my head around the spool and power this thing has made - a mild built (no porting, not extreme cams) RB26 with nearly 500kw @ hubs/665hp @ hubs with excellent spool on a PT6266 BB:
Thread:
http://www.gtr.co.uk/forum/166866-nats-r32-gtr-3.html#post1762728
Raises some eyebrows to say the least.
Things to consider, it's on SAE correction on old software so I would say it's around 600rwhp on a roller (but that's on normal fuel not E85)
You have to wonder how long the ramp rate is, 350hp at 4000rpm is about double what I would be expecting from that turbo
Edited by SimonR32
They are certainly capable of pushing beyond their power rating, but I've seen some figures floating around with way too much GST on them.
If they aren't done on an engine dyno or backed up on a track, they are just that...numbers.
No doubt, mine isn't getting pushed at all and it's starting to get right up there power vs power rating wise.
I just find it hard to imagine a larger turbo on basically the same motor set up as mine and Jez's is making almost double the power at 4000rpm and a huge extra wack of hp top end all while using 99 Octane fuel not E85
If I thought that graph was genuine and repeatable I would have already sent an email requesting an invoice for the purchase :)
Edited by SimonR32
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
