That's strange, can you show us a video?
I thought it was a bit strange. Its turning but you can easily stop it by hand. I've had the oil restrictor out of it to tap the oil feed fitting thread a bit deeper but I can't see that causing any issues. I'll take a video next time the car is running. It's still about 98% complete atm
  • 3 weeks later...
Here's the guts of a stuffed 6262 if anyone was interested in having a look. I can't understand why there isn't rebuild kits available for them as they are so simple to work on. The bearing assembly isn't even a press fit so you could do seals without having to spend a fortune. Would only be a matter of having the assembly rebalanced again
Edited by PSI086
I've had a few people quiz me about this car, maybe they didn't realise a 6466 is rated to 900hp :)
Yep people seem to treat this kind of thing as too good to be true, here in NZ it seems that largely people are uninterested or unconvinced at the new turbo choices from the likes of Precision, BW, Forced Performance - the Garrett GTX are getting some popularity, just because it's Garrett I guess. A bit of a shame really, the 6466 is just an amazing turbo from all accounts!
Wanting to see the dyno plot for me is so I can see how it comes on boost on an RB, most other countries stopped using T04Zs YEARS ago while NZ (and Oz even?) are still playing with them - given we're some of the bigger RB modifiers it means that there are lots of results around for them being a single turbo of choice, I'd love to see how the 6466 compares to a T04Z in terms of 'coming alive'.
Looking into the 6266 for a built rb30/25. Whats everyone's thoughts? looking for around the 600rwhp mark in an R33. anyone has dealings with both the Dual Bearing & Journal? Are they work the extra $$$
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
