For a single entry that is very impressive.
(looks at T51R) :ermm:
Yep I reckon the PT6466 CEA is Precision's best moment, it basically always seems to deliver - the better the setup, the crazier the result. Looking forward to Scr48's result... should drive very nicely on a 3litre and obviously the potential is there for massive power, even the .84 will make a lot but if it ends up not being enough then going to a 1.15 hotside would allow for unrestrained silliness :)
I'm not 100% sure yet, but one thing I am not sure of is if someone puts one on a high flowing RB (ie, RB30 with aggressive headwork and cams) if they will flow enough per psi to keep the big engine happy - they seem to be keen on high pressure ratios for their power, but that might just be the cars they've been on so far. Thats the only reservation I have at all, and it may not be justified.
Man the precision turbos appear to be the best bang for the buck. I know EFR and VGT are newer but you can't deny living proof!
FP HTA are very real competition, the 6466 is a particularly good offering however - but from FP you have the "rest" of the awesome turbos. Some of the best value for money turbos I could think of for small/medium sized engines in order would be (some real rough and realistic E85 power ranges):
FP GT3076R HTA - For 330-380kw @ wheels
FP GT3582R HTA - For 370-450kw @ wheels
FP GT3586R HTA - For 430-500kw @ wheels
Precision PT6466 CEA - For 500-600kw @ wheels (basically it just seems to do so much so well!!)
FP Super 94 HTA - For 580-680kw @ wheels (same as above - but larger scale)
Those are my favourite considering price, reliability, fitment, spool and power.
the 6466 is popular with the Supra fans so there are some results for 3.0L motors but results on the RB26 are pretty hard to find. The general consensus from what I read was don't bother with the 6766 as the 6466 is so damn good and punches above it's weight.
Our set up still has more in it, I've heard these turbos love 35psi+ so when we get it to hold spark we will go back on the dyno to see how it goes.
You and me both! Hopefully Friday!
Capacity: 2.6L
Comp ratio: Standard
Cams: HKS step 1's 272 8.7 lift (I think)
Exhaust: 4" dump into custom 3.5" exhaust with no mufflers
Will be tuned on E85 from the drum, the car is not my daily anymore and for $2,50/L I don't have to worry about watching the fuel prices jump up and down.
Because I'm not sticking with RB26 and don't wanna upgrade ECU's again.
Will utilize some of the additional channels from the PS2000 in the future.
A couple of people have also asked why the Logger IQ3, it's for same reason. buying now to setup so I don't have to replace in the future.
My aim is just to have a bit more poke when I press the accelerator down, I'm not chasing a power figure nor am I looking for a world record.
So finally got around to getting my car sorted, only to run into more problems.
I ended up with a Platinum Pro BNR34 specific model, and 3.5" dump not a 4"
Everything else above was fitted and turns out should've updated the valve springs too, thinking the 272 drop in cams would be ok with stock valve springs.
After a problem with the CAS & Valve float when you add any boost the car will be getting some supertech springs & possibly a Ross trigger kit and heading back for more boost.
What I ended up with was 494hp @ 13.5psi
I'll post up the dyno sheet later tonight when I get home and take it out of the car.
Another upgrade I will look at will be updating the coils or fitting a CDI & pencil coil kit
The 6262 sounds great, spools hard but I can't wait to get some boost into it.
The goal is still 20psi, I have no real power figure aim but judging on what it made @ 13.5psi its gonna go close to or over 600hp quite easily.
I'll keep everyone posted,
Cheers
Noy
Took a snap of the graph from the 6466 on the RB26 that JEM tuned the other month.
Soooo much midrange for the power output.
That is crazy, still 2.6?
Sent from my GT-I9505 using Tapatalk 2
Paul, I hope you are going to plot this for reference :)
I've done a quick eye plot ;)
I'd love to drive it. Dyno only tells half the story.
Errr and I sold those exact turbo which I was gonna put on my own car :(
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
