  • 3 months later...
I don't think there is any calibration as such? The sensor senses how far open it is and feeds the signal to the ECU as far as I know.
Adjusting your cable is another story. Take out the slack, and you could use a consult cable and software to confirm WOT. (with the car ignition on, but not running)
https://www.sau.com.au/forums/topic/313610-calibrate-tps/#findComment-5356473
what i mean about calibration is so the tps is sending the right signals to the ecu cause at the moment i think the tps is out of its right position, meaning that is prob sending a signal that the throttle is like 5% open when its actually closed.
i just want to know how to set the tps back to the right position so its like 0% thorttle and the ecu is actually reading 0% thorttle
get me?
https://www.sau.com.au/forums/topic/313610-calibrate-tps/#findComment-5357117
there has to be another way, like using a voltimeter using the resistants on it etc etc
It can be done that way, you will need to find out the correct voltage for it (EG: the 300zx tps is set to 0.45v at 0%) the easiest way to do it is to find the correct voltage for closed throttle and then get a multi metre in there and set it to it. If you have someone with either a consult cable or an ecutalk lcd display this can be done easily (5 mins)
Edited by RandomHero83
https://www.sau.com.au/forums/topic/313610-calibrate-tps/#findComment-5379118
yeah you can just use a multimeter to check the voltage. the voltage should be around 0.45v when closed. this is pretty standard for a lot of nissans. pretty sure the sr20 is also the same. there will always be a slight variance though. i'm not sure exactly what the allowable margin is, but if yours is dramatically different then i'd have a play around with it. if i get time i'll have a look through some stuff i have and see if it says.
https://www.sau.com.au/forums/topic/313610-calibrate-tps/#findComment-5379290
  • 2 months later...
get me?
Sorry for dig up this topic, hopefully i'm in the right place to post my problem. Currently my car(bnr34) MFD show the throttle reading at 1-2% when idle, for what I know it should be 0% when idle, I pop-up my bonnet and check the stop-screw, it is backed off without touching the throttle linkage(1mm gap), but why the reading show 1-2% when idle? Will TPS cause the MFD throttle reading like this?
https://www.sau.com.au/forums/topic/313610-calibrate-tps/#findComment-5501997
your MFD is probably guessing what '0%' means. e.g. if it has decided 0.44v is 0%, then if its reading 0.46v then it will show as 1-2%. maybe there is a setting in the MFD to calibrate the 0/100% throttle voltages?
https://www.sau.com.au/forums/topic/313610-calibrate-tps/#findComment-5505120
