Hi ABuSD, R33 RB25DET uses side feed, high impedance injectors @ 340cc and that's enough for around 340 BHP, 253 kw, 190 rwkw or 255 rwhp. Do a search and you will find heaps of posts on this subject.
I have a RB25 power fc, high flow turbo, front mount, malpassi reg, exhaust, dump pipe with standard injectors my car made 229.2 kws at wheels @1 bar boost with fuel pressure @ 90 psi @ 1 bar boost my air flow ratios were 11.5. Couldnt tune for more boost because no. 3 coil pack was breaking down.
Michael...
Ok GTS-t VSPEC, here we go again.
"It has alot of do with engine management"
Explain this to me, if I have an engine that shows an A/F ratio of 12 to 1 at 6,000 rpm at 1 bar using X brand ECU. How will it make any difference to the amount of fuel used if I have Y Brand ECU on that same engine that shows an A/F ratio of 12 to 1 at 6,000 rpm at 1 bar?
Same rpm, same boost, same engine, same injectors, same everything, how can one ECU use less fuel over another ECU if they both produce the same A/F ratio?
Now if you can't get the same A/F ratio with Y brand ECU because it has limitations, then that's a different story. But the A/F ratio won't be 12 to 1 and the dyno lambda sensor will show that.
I had a very long conversation (cost me many beers) with a couple of Motec and Autronic engineers at Bathurst and this was one of the subjects. As long as your A/F readings are consistent (they don't have to be correct, just consistent) then there is no way they could see where one ECU would use less fuel than another.
Maybe I've missed something, I am here to learn........
  • Like 1
I had my standard R33 series 1 injectors flowtested and they all flowed between 500 and 550cc? Or are you just saying that with the standard regulator they will only flow 340cc?
Also - I think GTST-VSPEC was just alluding to the fact that different tuners and different engine management can produce very different results. The engine management is like any other piece of equipment - it's only as good as the operator.
Hi caminperth, at 38 psi the R33 GTST RB25DET injectors are rated at 340 cc's per minute. I have cleaned and tested over 20 sets and they have all actually flow around 350 to 365 cc's at 38 psi. This is normal tolerance. If you increase the fuel pressure they will flow more, but at 38 psi they should only flow to their rating.
So if your injectors flowed between 500 and 550 cc's, then I would say they are either not standard R33 GTST RB25DET injectors or the fuel pressure was a lot higher than 38 psi.
In addition a 50 cc variation (from 500 to 550) is far greater than I have even seen, and would result in the cylinder with the 550 cc injector running 10% richer (and that's a lot) than the cylinder with 500 cc injector. The most I tolerate is 3% and I carefully select which cylinder each injector goes in ie; I put the highest flowing injector in #6.
Hope that clarifies
and when will i have to upgrade my fuel pump, is it when ive got over 240+rwkw??
On an R33 GTS-t i'd be doing this around 180-190rwkw. The standard R33 GTS-t pump is rated at 300bhp which is approx 180rwkw.
400rwhp = roughly 308rwkws'
400 x 0.746 = 298.4rwkw
But lets not get down to the nitty gritty :P
Is an aftermarket ECU "required" in order to use aftermarket Injectors? (ie; 550cc's instead of the standard 340cc's). Or will the standard ECU just continue on its way and pump more fuel in "if possible" ?
    • The boot notch on the GK Tech rods is different to OEM yes. You'll find a solution. They are a good rod, I have used many of them for various setups, and no they are not ' just for drift cars', they are fine as an OEM replacement. Same goes for the tie rod ends although I found they transmitted a huge amount of NVH a normal balljoint masks, making it feel like there was something loose or knocking, even though there wasn't. If you used the same pieces on each side, no reason one angle should be different to the other side. Have you checked ride heights/measured the angles? Or just visual? Your alignment will be massively out of whack yes. Up to you; it is worth taking the time to learn wheel alignments and do it yourself. I have never had better wheel alignments and I haven't taken my car to a shop for, dunno...many many years. Spend a few hundred on equipment, do alot of research via online articles, youtube vids, and "trial and error" on setups. Eg, set it with too much toe-out, toe-in, too much or little caster, drive the same stretch of awesome twisty mountain road each time, learn how they feel and how the car's handling has reacted to your changes.
    • Won’t be hard to beat them. 🤣 Farken sponge cakes!
    • Nah I did not will have to another time. I only installed a blitz return flow FMIC probably 1000kms ago. When I took the old piping off there was basically no oil in piping. At this stage it has to be valve stem seals. When I roll down a big hill in gear and then throttle down the bottom, I get the same puff of smoke.
    • I believe when they added coolant to cool the turbo it negated the need for turbo timers as water continues to flow even when the engine is shut off I forget the actual terminology, I'll just say the coolant "percolates" through the turbo which stops the oil cooking itself to death  Well....that's how I see it, as all the plant at work that has coolant lines to the turbo can be shut down straight away, whereas the older plant with only oil feed to the turbo you need to idle it for a few minutes
