ok so i recently installed a basic highflow turbo from hypergear and a split dump/front pipe from JJR. i made sure i die grinded out the wastegate section on the dump so it can open fully. also im not running any boost controller its straight off the actuator
dramas.........
so the cars running fine except the boost is creeping. boost builds up to 9-10psi as normal and stays there for about a second then creeps fairly quickly to about 17-18psi then i back off (may creep further but i dont wna try) and the weird thing is its not hitting R&R or boost cut im running standard ecu atm.
so ive blown compressed air into the actuator and the wastegate arm only moves half of what its supposed to (around 45degrees) which made me think its the split dump. so i took off the little circlip and took the actuator arm off the wastegate flap and moved the flap with my fingers and it moves the full way (around 90degrees)
what other tests can i do? does the actuator sound like its stuffed? can it be modified?
i am getting a nistune as soon as this prob is fixed
https://www.sau.com.au/forums/topic/313647-overboosting/
Check to make sure its getting direct boost source.
If they've modified your stock wastegate actuator braket then all you need to do is losen up 2x screws that is holding it and play with the fitting angle
I got mine setting on 12psi without controller, and the max my stock actuator could hold was 16psi.
https://www.sau.com.au/forums/topic/313647-overboosting/#findComment-5151018
stao from hypergear rang me today after reading this thread so +1 on hypergears service.
im gonna try drive with the actuator arm disconnected to see if the exhaust is a restriction and then i might try play with the actuator. when the engine cools down ofcorse
https://www.sau.com.au/forums/topic/313647-overboosting/#findComment-5151852
with the arm disconnected it boosted to 14psi. im guessing it is the exhaust then, not fouling but restricting flow
if i plan on running say 15psi would this be a problem or would the engine build higher boost in say a higher gear under load? i did the test in second gear and pretty much took it to redline
https://www.sau.com.au/forums/topic/313647-overboosting/#findComment-5151922
that sounds like a reasonable theory by stao.
on a stock turbo its probably not as much of an issue and ive seen people struggle to run under 1 bar with that type of exhaust before anyhow, so hiflow and your boost issues seems reasonable.
get a bell mouth dump :)
https://www.sau.com.au/forums/topic/313647-overboosting/#findComment-5152385
We didn't install a larger flap its not needed. But we did port it out to about 26mms from 24mms. This is to all high flowed units, It have worked well, I have not had any one had boost control issues with it yet.
Go big isn’t always better, Bad point with larger disc and massive wastegate port:
You need to know the force exerted onto the actuator is: Pressure x Area.
If we use a 32mm disc and port that out to 30mm. Then we will have a massive boost drop towards red line. Most of use have seen this happening with internally gated GT30 units and high flowed units. Boost clam to 18psi in 4000RPM then drops back to 15psi by 7000RPM.
With this small .58 size housing running 30mm port we will definitely have issues holding boost up top. And don't think "big can" actuator helps, I've tried it, it does not work.
In our ATR43 G3 and G4 units which requires a massive 30mm internal waste gates to avoid boost spike and still be able to run flat 20~24psi, we’ve come up with this unconventional method:
to deliberately create a controlled boost spike, so we won’t have boost drop and power lose up top.
https://www.sau.com.au/forums/topic/313647-overboosting/#findComment-5152597
Had a read at your previouse post. We believe boost creep is caused by your dump pipe
Yup. I've heard many reports of boost creep on split dumps. Mostly JJR ones, as it happens, but I'm sure there are others. It is utterly pointless trying to bandaid the situation with bigger wastegate flaps when your gate isn't opening past half way!!
A split dump has to be engineered VERY well to work properly, and while it's a nice idea the risk of your wastegate fouling on the dump does not appeal to me one bit.
I went for a JJR bellmouth dump and was well impressed by the build quality, neat TIG'd welds etc which is amazing for a chinese exhaust. The $400 metal cat was so messy it must have been stick welded to the flanges, at least the inside was clean. 180rwkw on stock boost.
Plus, think of it this way.. a split dump may get you slightly more performance at WOT, if the hype is to be believed. However a bellmouth dump gives you a big open pipe (there is WAY more pipe area for gases than a split dump!) and you get that whole area, LESS RESTRICTION, all the time. So your part throttle fuel economy should be better. It's just better all round, I'm going to stick my neck out and say split dumps are a dumb idea unless you've got a lot of money to spend doing it properly.
https://www.sau.com.au/forums/topic/313647-overboosting/#findComment-5152873
I bought an JJR split pipe a couple of years ago, and had to modify it to fit my 240z / rb25det kombo. When I cut the pipe just after the bottom bend, I discovered the where the smaller pipe merges with the bigger, there were just a square hole. And that opening was a fair bit smaller than the small pipe. Used a Dremel, and fixed it. But could this be the source for all problems people are getting with boostcreep with the JJR split pipe?
https://www.sau.com.au/forums/topic/313647-overboosting/#findComment-5152935
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
