Looking at the possibility of upgrading my current 17x9 Buddy Club P1 Racing to some 18x10 Buddy Club P1 QF's. Now they're currently fitted to an R33 GT-R and look absolutely brilliant in Gun Metal Grey. Have been told that these rims have an offset around the +12 mark I think - they're extremely dishy. The +12 offset is an off the shelf spec for this particular rim.
Has anyone put 18x10's on to an R32 before and know what offset was required to have them fit? Note that I have a normal suspension setup (sorta - rebuilt std shocks and whiteline lowered springs). The current 17x9's are at a great height, almost perfect distance around the whole guard rim.
Have attached a couple of pics too and the URL below:
http://www.first-inc.co.jp/buddyclub/p1rqf...qf/p1rqf_f.html
Note, this is just a possibility at this point in time.
https://www.sau.com.au/forums/topic/31365-18x10-rims-on-r32-gt-r/
17" Buddy Club P1 Racing are around the $2-2.2K mark with tyres. I bought my rims for $2K second hand, but they were yet to be used so they were effectively new. I think a new set could be around the $1800 mark for 17x8's (f) and 17x9's ® as per C-Red's parts page:
http://www.c-red.com.au/parts/index.shtml
I think P1 Racing II's will be another $3-400 more expensive. Colours available are Titanium Silver, White and Hypergold, but you could get them resprayed whatever colour you wanted I suppose and get Jeff at C-Red to get you another Buddy Club sticker for the rim.
Now, back to my question.
  • 3 weeks later...
As a matter of fact yes. Although they do stick out a little. Have fitted them today actually:
Buddy Club P1 QF
18" x 10.00JJ +12 Offset
245/40R18 Tyres
Tyres are stretched on these rims but brings the tread under the guards:
http://www.ipixel.com.au/temp/p1-qf-r32gtr/
Let me know what you think.
Cheers
Brendan
I'll find out prices (I did a swap on my old P1 Racing rims and contra work for them) and get back to you. BTW, they're an extremely lightweight rim for an 18" coming in at 7.45kg/rim.
Don't expect prices for the rims alone to be under $1K each though. Otherwise contact Jeff Ash at C-Red (they're the official Australian agent for Buddy Club) and he'll be more than happy to help out in price department.
Cheers
Brendan
Just had a quick look. Rears there's plenty of room (30mm+) between edge of rim and suspension strut. For the front, there's less room between the upper link support upright (couldn't find correct name in manual), but seems to be around 15-20mm clearance when wheels are centred. Biggest clearance problems would be between tyres and inner (plastic) guards. On full lock, the rear of the tyre (being inside guards) has minimal if any clearance (haven't heard any rubbing), so tyres larger than 245 section width could rub (of course then you have the option of removing these and lipping the guards. Height wise, I'm using Whiteline's lowered springs from 'the Works' package. Guard lip is around the 325-327mm (note: very dodgy measuring with a 300mm ruler) from the centre of the wheel hub.
If you've got a good relationship with your tyre shop, they may allow a few different fittings of tyre sizes to work out the best for your particular application.
Cheers
Brendan
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
