Noel - You'll need to call me on this one. I've sent you two text messages. Circuit Club haven't received your payment and accordingly, they've cancelled your spot.
You'll need to send me your deposit date, reference and amount in order for me to have them track it down.
Liz.
  • Replies 124
lol Ben. dont you just put 200ml of fuel in it and just turn up?
Gonna be another last minute effort to get everything ready as I have zero time during the week to test anything or make adjustments grr.
can i organize an appropriate temporary license on the day?
Kinda last minute decision, as I'll now be taking Leif's spot for this track day and it'll be my first so I'm a bit unsure of it all
pretty sure you can purchase the wakefield liscence on the day
Seam: They provide you with numbers when you sign on.
ITINERARY
7.30: Gates Open - Drive in, sign in and get prepared!
8.45: Driver’s Briefing - This needs to be done before you are
allowed onto the track. If you haven’t signed in by now, you may
miss your first session on the track.
9.00: Track Opens
4.00: Track Closes
ADDITIONAL INFORMATION
Clothing: You will be required to wear long sleeve clothing and
closed shoes with socks. Helmets are mandatory on the track, one
can be arranged for hire if necessary.
General Car Condition: Please make sure your car is in complete
working order and you have no leaks or loose items in or around the
car.
Getting There: Wakefield Park is about 10 minutes outside of
Goulburn, located on Braidwood Rd. The turn off for this road is
right near Goulburn train station, with a big blue sign pointing the
way!
Sessions: There will be 4 groups on the day, classed by lap times and
experience. Remember, if you are having any issues with your group
on the day, see me!
probably would be a good idea to have the battery isolater switch position marked. The rest i think you have covered.
i recieved the itinerary etc from circuit club today but my computer wont open PDF anymore. anyone else get it? what does it say?
Does the car need any markings? Number, blue triangle etc? and just neck to wrist to ankle clothing + helmet I assume?sry if these are silly questions
I'll be located in the first row of garages with my red ute parked on the grass infront of my garage.......be good to get everyone grouped together to help each other out.
The CircuitClub trackdays are brilliant because the sessions are longer, a typical trackday is usually 6-10 laps where as the last CC Wakefield day I did was up around 10-15 laps.
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
