Hi,
I've been following an eBay auction on a manual R30 (link)
It's been sitting below reserve for days after two previous listings with no bids. Same car was listed by a different seller last time.
Now all of a sudden, the bid history shows three bids from the same bidder, who has taken the price from $350 to $500.
e***f( 0 ) AU $500.00 26-Mar-10 13:17:30 AEDST
e***f( 0 ) AU $450.00 26-Mar-10 13:17:18 AEDST
e***f( 0 ) AU $400.00 26-Mar-10 13:16:51 AEDST
w***e( 0 ) AU $350.00 24-Mar-10 21:13:44 AEDST
I'm not bidding so this is just academic. But am I right to assume this is dodgy?
JohnH
https://www.sau.com.au/forums/topic/313671-dodgy-ebay-bidding/
Not necessarily dodgy. What it means is that e***f has entered a reasonably high maximum bid...of say $1000 (for example). They've become the highest bidder at $400, overtaking the previous high bid of $350. But then someone else came along and bid (for example) $440 on it, which was immediately and automatically overtaken by e***f because his maximum bid was higher than $440. Then ANOTHER user (or possibly the same one given the close timestamps) has come along and bit $490 (for example) on it, which was immediately and automatically taken over by e***f's maximum bid again.
Where it can be dodgy, is that the seller may be using another account to push e***f closer to his maximum bid. But e***f is not necessarily dodgy himself/herself.
So the bidding system doesn't display the intervening bids?
Seems legit...
If reserve is $500, which I think it was if it is the car I am think of, then the seller could have got a mate to bid up to $1 less than the reserve to push the price up, but probably it would have been one buy the buyer at $500 exactly... for it to have a reserve of $580 is unlikely, so it was probably 2 genuine buyers...
Cheers,
Darryl
check these ones out too:
ebay r30 (3)
there are more for sale now than i have ever seen in my life...
pity none are quality though!
I thought the hatch would catch your attention, with all those turbo bits and an anniversary badge!
JH
Hi,
JohnH
It could also mean that the seller wanted at least $500 for it, so got a mate (w***e) to bid in small increments to up the bid to $500. It doesn't help that the seller can see (for example, not saying this happened here) that e***f put in an opening bid, then added another bid in the history. That's a green light for the seller to get some shill bidding going on.
The thing with ebay is, that you have to expect that the item will sit near its starting price right up till the last few hours before it ends.
If its is bid up alot before then, then the bidders are either stupid (new ebay bidders make this mistake) and must have it and bid early, or something dodgy is going on.
If you want to win something cheaply, you try not to bid until the last minutes, otherwise your just driving the price up in the days prior and end up paying more. And if your a seller, start the item off near what you want for it.
Hi,
Thanks very much for the info. I'd never heard the term 'shill bidding' and, being new to eBay (and also slightly stupid!), have bid way too early on items. A real life auction takes place in only a few minutes. These 5, 7 and 10 day auctions are a bit of a trap for beginners. (EBay has a help page on shill bidding here.)
JH
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
