I'm doing some research for a planned build.
Decided i'd take a rwd 26/30dett route.
I've had a bit of a browse through this section and see mixed reports when it comes to finding good rb30 blocks to use.
Does anyone have any recommendations, or is it just a case of luck of the draw?
If theres is a source of good condition blocks, anyone have an average price?
Had a look, no mention of just the blocks, only assembled bottom ends, its the same with rips.
Ideally i'd like to pick up an xrayed and cleaned block i could get on with the buld with (boring etc etc to be done much much later)
you pay about 100 to 200 for them. i got my one for free off some dude off the vl website. gave me full motor and gearbox and all the stuff. there not really worth anything. i doubt youd get many that wont be useable. there generally pretty good still with hone marks after 300000kms and stuff. if it happens to be out of round it will be fixed if you bore it out. think it cost me 60 to hone it and 180 or 250 or something to get it bored out. some wreckers want 330 for them but one guy said he gets them for 150 all the time.
put up a wanted ad on here and any other websites you know and you should get one pretty quick
No one is going to spend the money/time checking out a block just to sell it as is, they will then assemble and sell that way.
just buy a block for $100-$250 and spend your own money getting it checked. I can't see it working the way you want unfortunately.
Sorry to be the bearer of bad news, but you'll never find one like that at the price you want to pay.
As Ash said, go get a block and do the work yourself :thumbsup:
Nice :) well for the money mentioned above i have no problems buying a few if the fiorst doeasnt work out.
I was just worried they might cost a bit and have a high risk of being busticated.
As a general rule i dont mind spending up where its a smart move, i just hate the idea of spending lots for a unknown quantity.
With what you've all said... i think its time to go shopping.
yeah it does happen, there are some bad ones out there. the first one for my stagea was cracked, didn't find out until it was xrayed.
fortunately in my case the workshop supplying it replaced it. but even so its only a couple of hundred if it doesn't work out
r31's are about 500 bux
you get an engine with the car
hmmm thats a thought... it could give me someplace to put the rb25 that i'll be putting out of a home.
more seriously, your spot on with this, and it looks like a good option. it would mean i need a bit more kit to get going.
I'd need a crane to pull the engine then i'd need to figure out how to get rid of the body quick afterwards (not alot of room here).
but atleast now i kinda have a plan and i can get cracking.
I'm doing a search, but while i'm at it, can anyone recommend a good engine stand??
yeah get one rated to more than just the basic
this style: 80.jpg
not this style:80.jpg
these motors are damn long and damn heavy. and make sure you've got good bolts with plenty of thread to connect the motor to the stand
this style: 80.jpg
agreed, if your buying a cheapie, the 4 legged buggers are the way to go, if your willing to spend the coin... Bluepoint makes a wicked collapseable 3 legger.
they hold the rb motors very very easil, i also have one of those 3 legger cheapies... i only use it when i know i dont have to move the motor around as i dont trust it much even tho it hasnt buckled or anything with a motor sitting on it for about 3-4months straight. even with blankets and other shit thrown over it
i only use an engine hoist, then once the engine is removed from the car i place the engine on the ground on 2 layers of thick carpet.
working on the donk on a stand would be easier BUT it wont fall far if its already on the ground :down: simply sit on the floor and start stripping it down
Problem with it being on the ground is after half a day your lower back will be screaming at you
No it doesn't as you're sitting beside it. When on the stand you're bending down and your back hates you. The last few I've done on the ground, the next one is getting a stand as I want to be able to put it up side down easily.
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
    • Yeah, but "restomod" implies Singer and things like it, which implies drug money / trust fund maturity.
