  • 8 years later...
It's pretty easy really - remove engine, dismantle everything, measure / test everything, repair or replace everything that needs it, put it back together (assembly is a reverse of the disassembly process), and put back in the car.
Seriously, as Callan said, if you need a guide you should consider if this is a job for you. Have you read the Nissan engine manual? There is a PDF version floating around the internet, which covers most of what you'd need to know.
