Broken Clips On Coils
sacko88
 Share
Anyone know if and where i can get new clips to connect to the coilpacks?
The previous owner broke the clips when changing the spark plugs..
Any help would be great..
Yeah the snap locks are broken on every clip and i have had trouble previously with a bad misfire which i cheapley fixed by cable tying the clips so they wouldnt vibrate loose and that has been fine..just thought it woud be good to get new clips..
if its the snap-lock bit you can get away without replacing it. one of mine have been snapped for around 2yrs and is still going strong.
nah from what i can tell the wiring side of things is fine just the plastic clips being brittle..
Besides the clips going brittle, has the wiring gone hard/stiff too?
Just Jap? or Not-to-worry, as Joe said.
sorry i drive a 95' R33 GTSt. thanks for the advice
very cheap from nissan or just jap whoever to buy the coil pack loom for a gtr. your profile and post dont say what car you have.
 Share
    • There are fixes for this. In industry we use compressed air for everything. It is frequently wet, and many things cannot tolerate it. So there are various forms of driers available that you can install. The simplest option for something like this would be a dessicant drier. Much cheaper to replace some silica gel than actuator cylinders.
    • That's a solid update mate, well done at WA FOS. You may already know this, but the actuators on the paddle shift are a service item and are sadly not that reliable. As I understand it they collect water from the compressor (condensation) which then rusts the bores/pistons in the actuators. A mate of mine had no end of trouble with them in one if his circuit cars, apparently it's a 'known issue'. Buy a couple of spares at great expense to ensure you never have any problems with the ones you've got! Any clues about what the new WTAC rules might be? While faster cars are cool the Pro class arms race has got to the point where you wouldn't even bother entering without a $1m budget and even then I don't think you'd win.
    • https://nissan.epc-data.com/skyline/er34/3945-rb25det/trans/317/31940N/ The pictures of the part you're talking about is clearly not just one solenoid. You can see another picture of it here: https://www.alltranz.com.au/shop/drivetrain/automatic-transmission/RE5R01A/product/9305/ The 4 speed automatic in the GTT is Nissan corporate stuff. You can search up similar jobs done on a Frontier or Pathfinder with a RE4R01B to get an idea for what the internals are going to look like and the procedure like this:
    • Hi Chris,   long time since your post, just wondering if you have the Pinout for the v35 stereo plugs, I bought the roem nis2 harness but it doesn’t match the v35 connector. any help appreciated, I can work out the grn and power constant. But the rest might be hard. thanks Tyson
