Okay guys unfortunetly the proposed GTR competition did not attract enough interest so we have come up with an alternative which is running regardless.
There is still a car display at the show but it will be a variety of cars rather than just GTR's, entry for this display is free.
All participants will still get a free lunch both days and will also go in to the draw to win a helicopter joy flight for 3 people just by having your car on show!
So if you have a car you think stands out contact me asap to enter your car!
Get in touch soon as space is very very limited...
[email protected]
https://www.sau.com.au/forums/topic/313775-display-your-car-free/
Guys the show details are as my signature reads...
1st and 2nd May 2010
Bankstown Airport
Hangar 273
If you do enter your car it will need to be displayed both days.
Helicopter flight will take place at approx 2pm 2nd May 2010.
List of stands inside the hangar to date;
1 - Emirates
2 - Airport model display
3 - Aviation Photography
4 - Angel Flight
5 - HARS (Historical Aircraft Restoration Society)
6 - Aerovideos
7 - Holdsworth Airline Collectibles
8 - CAM Australia/Aeroclassics
12 - Careflight Helicopter Simulator
13 - Careflight
16 - Models (Private)
17 - Ornamental Castings (Aviation GSE)
18 - AUSCAP
19 - Australian Air League
20 - Australian Air League
21 - 1/36 scale Airport scene
22 - Sydney Aviation Shop (Custom Models)
23 - Sydney Aviation Shop (Custom Models)
24 - Food Stand
27 - Sydney Warbirds )Adventure Flights)
28 - Century Wings (Military Models)
31 - HTT Helicopters (Joy Flights / Flight Training)
32 - Red Baron (Joy flights / Flight Training)
33 - Combat Dragon (Adventure Flights)
34 - Ice Cream Van
36 - Gemini Jets (Diecast Models)
There will be the static aircraft display outside the hangar with upto 15 aircraft on display!
Looks like you've got a good roster there Dan. Good on the CareFlight guys, good to see them getting support.
Yeah mate we try to have a variety on display and for sale through various outlets.
We also like to support the charities that give some much back and Careflight as well as Angelflight are both participants at the show which we will also be supporting!
  • 3 weeks later...
i would but my car got keyed two weeks ago so... it'll be a while b4 it can actually be displayed... i'd love to come along and check things out though
Mate thats a shame...
You should come down and have a look, should be a great show!!!
you should also try some other imports like Evos, silvias, supras just to name a few. atleast you sure that you will get the number of cars you want
Totally agree!!!!
All cars are welcome to attend!!!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
