  • Replies 52
we have a japanese version of the manual in paper format. hence the delay.
if you rekon you can get one on yahoo faster than i can be bothered scanning it, then by all means go for it!
ive only ever seen two on yahoo, and i now own one of them ;)
well done Scott!
Don't worry to much about the gearbox shift mate.....manual valve body with paddle shift is the way to go!!!
anyone want to buy a Haltech!!! ;)
I could put the Haltech on my mower I guess, it doesn't get above 6 grand revs. :devil:
I thought a gtr box was the way to go mate? Then it was the pathfinder. When are you going to upgrade?
Just got back from a nice run, the auto is shifting instantly now as there is no throttle closing between shifts. It actually chirps gears now.
Watch out for those hoon laws Scottie, don't want them saying you were doing a burn out........ all 4.....lol ( ;) )
ive only ever seen two on yahoo, and i now own one of them >_<
Ah yer sweet, i got a scanner here at work that does manual feed into pdf :D
but you have to pull the book apart obviously..
i was just wondering about the Attesa/4wd system and more so its similarities with the gtr and whether i can throw my spare controller onto it..
Glad the Throttle has worked without troubles Scotty!
Wiring? Just wack the throttle in and toss the electronic one over the right shoulder.
I dont even run the tps anymore, you will need the Greddy map sensor though.
Roadtrip? >_<
Looks like Cihan will be busy. He wont let me hand the map around unfortunately either, too much of our time and money invested. Looks like you will have to drive down mate.
Perhaps you can convoy down with Craig? :D
i have all the required parts. except for the throttle body that is lol
is there no way of connecting a TPS to talk to the gearbox input? or is the kickback a single signal from the ECU? the emanage might be able to manage that................
also, whats your cruising like? does the torque converter lockup still work properly?
No idea (yet) if the auto computer has a separate input but if you use the ecu to do it, with a new tps, it will dump more fuel and defeat the purpose of going standalone.
Manual control of the gearbox would be good, with lockup in manual and no lockup in drive perhaps, or just full manualised, piss off the gearstick and run paddle.
6 speed manual even better, thats what I want eventually. I need a clutch pedal.
scott how do i make mine shift quicker????????????
Shift kit will fix most of the issue. The rest is throttle dependent, either chip the ecu or wait till I sort out the cable throttle teething problems.
Anything you change from factory setting will detrimentally affect the cold start and smooth driving of the stock ecu map.
Doesn't look like it, the water temp isn't hooked up to the Emanage.
Another issue I found today, the variable valve timing isn't working. :cool: Anyone know how the Vmanage works?
I may be refitting the elec. throttle, I want my midrange back.
read the manual. its in there, not all THAT difficult AFAIK as it uses RPM to activate the solenoid. so you might be able to activate it later or earlier to make the car run better
It looks like the Vmanage will work, should pep up the throttle response.
I have a really lumpy idle and no surge in the midrange like before so I guess its only running on the high lift profile?
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
    • That ring thing is interesting how it's holding everything together
