Remembering that all my mods need to cost me almost nothing to stay within the spirit of the racing.
Is there such a thing as easy brake conversions? I was hoping that I could just swap over R31 Skyline stuff, but it doesn't appear that way.
I thought that the rear caliper mounts were bolted on, but they appear welded to me... mostly I wanted bigger rear brakes, as overheating isn't the issue for the short tests I do (1 -2 minutes each test)... I just need bigger rears to get the back out coming into the corners...
Also, rear caliper rebuild kits seem to be $75 each as cheap as I can get them. Is there a cheaper kit anyone knows of?
Cheers,
Daewoo
https://www.sau.com.au/forums/topic/313814-mr30-easy-brake-conversions/
one option is to use 2 sets of calipers on each side, a bit complex though
second option is
hydraulic handbrake setup for the rears will get the back end swingin! disk rear only of course!
Garage7 in Adelaide make them to suit . about $300 and VERY strong
http://www.garage7.com.au/ but the web page is down
Address:
Unit 2
33 Light Crescent
Mount Barker
SA 5251
Phone:
Workshop (08) 8398 3107
Declan 0421 878 818
Luciano 0433 767 447
Web:
www.garage7.com.au
[email protected]
or by PM
Cheers,
Declan
Find a wrecked out dr30?? I sold one with complete suspension and brakes for $50 once
Are DR30 brakes bigger??? Bigger rotors or bigger pad area?
Front brakes are easy.
Use modified VT Dunnydore, cost all up about $100.00 2nd hand, or Hilux 4 spots and maybe Z32 rotors.
D
Interested Dennis, I might get the details from you later... ATM I am trying to get the rears working better.
second option is
Cheers,
Declan
I've got a hydraulic handbrake... got a cheapie of eBay and changed the cyclinder to a better sized one I had in the shed... but the pad area at the rear just isn't big enough to overcome the locked diff and auto transmission... figure I just need a calliper with more pad area... and increase in rotor size would be a bonus... looks like I'll have to hit the wreckers with my trusty verniers...
Is it normal for the rear calliper mount to be welded to the swing arm???
Cheers,
Darryl
Yes! DR30 rear rotors are 290mm as opposed to 250mm in the MR, but the pad area is about the same. They rely more on the leverage of the 145mm radius and the difference in the mounts is all on the caliper leg.
Yes, normally. The only bolt on rear caliper mount I have seen in recent times for a Nissan is the N12 ET Turbo Pulsar and they are extremely hard to find.
Cheers, D
Cheers,
Darryl
N15 Pulsar are bolt on... as are R31 skyline... I unbolted the drums off the back of my N15, and bolted on R31 Skyline rears and they lined up perfectly... pretty sure the rear disks are a bolt on an the N15 Series II and SSS, but can't say 100%...
Cheers,
Darryl
Cheers,
Darryl
D,
Just checked,
I still have the caliper brakets that bolt to the rear axle of an N15 Pulsar. I still had the brakets, but unfortunately have thrown away the full set of Pulsar SSS Brakes... that is what you did before eBay when you couldn't sell your crap to other idiots...
The bolt spacing for the N15 rear calipers is the same as the MR30 rears. Don't know what the rotor offets are, but might be worth some investigation... once you know the standard SSS Pulsar ones fit, then you can look at what Pulsar guys do as rear conversions...
Just thinking...
Cheers,
Darryl
In addition to what Dennis (correctly) said, the piston is 10mm (IIRC) larger - ~45mm vs. ~35mm.
You will also find these brakes on the rear of a Z31 300ZX.
The 1982 R30 Skyline came with rear drums. You can remove the drums and make your own rear caliper mounts, utilising the original drum mount bolt holes. Just the same way as people mount discs to the rear of a 1600/180B/240K etc.
The only problem is finding those trailing arms, and then finding a spare pair... :cool:
ive used hr31 rear Aarms in my c210 coupe project with r33 turbo calipers/rotors and started 2day fitting hr31 Aarms to my dr30 which will run r33 gtr brembo calipers/rotors allround with the 1 1/16 gtr master cylinder. hr31 uses internal handbrake and later model brakes go on with little fuss.
jon.
The only problem is finding those trailing arms, and then finding a spare pair... :blink:
You mean like the ones that were on the back of the sedan I sent to the scrappers a few months ago :) :) :)
I didn't realise that the Sedatch ones were welded until I got them apart...
At the moment I will persist with the standard brakes, it was really only to try and get the hydraulic handbrake to work better...
Anyone ever rebuilt the standard rear calipers??? I mean all the way to getting the handbrake mechanism out and back in again... I am never doing that again, what a pain in the @rse... you need six hands and exray vision... and after all that, it seems the problem with the (standard) handbrake sticking is probably a shitty cable anyway... :verymad: :verymad: :verymad
Thanks for all the replies...
jon.
Why on earth would you want this amount of braking power on an DR30?
You planning entering this car in Le Mans or something???
The DR I'm building will have stock DR rears, 10" DR booster, DR 1" m/cyl & BNR32 GTR fronts and I'm sure I will easily pull it up from 220~240kph.
Sounds like a lot a fart arsing about for next to no real benefit.
Wouldn't your time & effort be better utilised making the car handle & steer better?????
What size wheels and tyres do you plan using with this brake set up?????????
D
easy brake conversion if u have hr31 Arms which can be had cheaply enough if u find 1 wrecking...
Y? because i can and got all the stuff at a good price so y not.
lemans? not at this stage.
yours sounds like a good upgrade but i wanted to upgrade the rears aswell.
next to no benifit? bigger are better are they not?
time wasted? its taken me 2days at the most and im also doing suspension/steering upgrades
wheels are work vs 18x8 & 9s 5stud > z31 hubs
ive wrecked out a few passages so had these hr31 Aarms sitting around and they mount quite easily to r30 crossmembers, the 4bolt turbo half shafts are an upgrade if your running an r200 and the stock hr31 turbo rear rotors are ventilated and of a good size but use a slide caliper. brakes can easily be upgraded for r32 onward twin piston setups by having the rotor redrilled ( if staying 4 stud ) and the caliper spaced 1.5mm with a hardened washer... not hard at all???
jon.
D
because it will be turbo, and who says he isnt doing handling stuff? lol
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
