Hi guys and girls,
Got a bit of a problem have put a rb20det into a 4 door 32 but have come across a bit of a problem. I have fuel and I have spark but the injectors aren't pulsing and I have replaced CAS to see if that was the problem but it hasn't changed. The motor cranks and wants to start I even sprayed Start Ya Bastard into the throttle body and it started to run but wouldn't continue to idle just ran back to cranking.
What could it be???? I've looked around and its said to change CAS but it still hasn't helped.
Your help will be appreciated.
Ta,
Kails
what was in the car before the 20 went in? stock ecu and wiring on the 20?
Yea engine, ecu and loom came out of my 32 2 door (it was a stock engine, loom and ecu) it got transplanted into a 180 never wired in just sat there and then have gone from the 180 to the 32 4 door so unless maybe its been sitting for a while and injectors have seized or something?????
No injector pulse still sounds like CAS issues.
Are you 100% sure it was the right CAS?
i've got a couple of spare ones so might try another and see if it works just unsure if there could be any other problems it could be
:S
If you have spark, then presumably the CAS is working correctly.
As I asked in the other copy of this thread (!!!!!):
Have you got power (+12V) at the injectors? Did you have the injectors cleaned before you installed the engine.
with all the engine swapping its possible the power to the injectors hasn't been rewired.
you can either check the injectors for 12v positive power at the injector plug itself or at the ecu. do you have a RB20 ecu pinout? they are easy enough to find if you don't. at the ecu check pin 109 has 12v (positive), you can also check that pins 107, 108, 116 on the ecu are grounded (negative).
    • Hey, it's me! Though honestly, if I had 20M in my bank account tomorrow, I would not want to be rid of my car all of the sudden - Which makes me think this is money stuff, not "I actually hate car" stuff. I'd probably double down and buy even more trinkets and fun things for it. If this is not you, then sell it cheaper. It will sell at a certain price after all.
    • This is the LCA mount reloctaion kit. Self explanatory in its description. https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=62&_fid=1e812d392&_ss=c These are the alloy subframe bush inserts that I am using. I like them. https://au.gktech.com/products/rear-subframe-slip-in-collars?_pos=29&_fid=1e812d392&_ss=c Alternatively, if you have original and shitty bushes, you might consider outright replacement with poly. https://au.gktech.com/products/polyurethane-rear-subframe-bushes?_pos=28&_fid=1e812d392&_ss=c I would also higly recommend that you look into adjustable RUCAs and tension rods, so you can sort out the camber and bump steer behaviour, especially if the car will be any more than ~15mm lower than stock. I would also highly recommend the GKTech FUCAs, although you really should do some research and learning on the subjetc of R32 FUCAs before making any decisions. All of this will be criticaly difficult to get through a TÜV inspection too, if that happens to be relevant to you. Note that if you do install the relocation kit, you will absolutely have to replace the associated bushes with spherical joints (you can read all about that on the product page) or upgrade the LCAs also.
    • I picked up my block and head last week and have been slowly assembling it since then. Pictures I took earlier this week. The rest of the auxiliaries are on now. I just have my intake manifold runners to tap for my WMI direct port setup before putting it back on. I should hopefully have the motor back in by this weekend.
