Fs: [syd] 1990 R32 Gtr
sorry but is it me or is the first engine bay pic different to the 2nd one? (at quick glance)
where's the abs unit? different pods? missing a plate on the firewall? strut brace gone? different fan surround or different sticker? cover?
Louie I'm interested in this too... Seems like the photos are from different cars. Before I come and see it tomorrow can you confirm whats going on here?
'same same but different'
did you buy it dimi?
Haha nah. I was going to throw a good offer to him today but read that it was sold. Feck.
It's all good.
There's one up for sale in Queensland with an R34 engine. I'm going to try and run a check on the engine and if it's genuine i'll sus it out :D
You looking for one too?
It's all good.
I flew up there on Saturday just gone. Went and saw that one - it's not a R34 engine, just the covers. It also has no rego (out since July last year), and has a space saver on the front.
Not bagging the guy's car or anything, just saving you a trip up. Lucky I actually found the right car up there the same day.
As suspected. You saved me a trip up. Thanks mate.
that engine bay pic on the top of this page looks exactly like this black r32 gtr i saw at japlink motors begining of year....the way the abs lines are t'd to one another....why take out the abs anywayz?
'Cuz the pricks leak like nothing else - it's easier to remove it than to reco/repair it.
It's all good.
There's one up for sale in Queensland with an R34 engine. I'm going to try and run a check on the engine and if it's genuine i'll sus it out :P
I don't know yet.. just sold mine - but now I've paid for what I had to pay for (at that time) and had extra cash left over and now have to decide to either buy house or another GTR again..... having withdrawals you see.
with the said GTR (with apparent 34 motor) ask 'Elite32' or 'yaface' about it
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
