As in topic wanting to see what jap exhusts you guys are running for r33 that are relatively quiet and I dont mean quiet as in stock but not ridicoulously loud so prob up to 95db as I dont want to go purchase one then to find its pretty much the same level as the one I got now. epas are on the rise these days and cant be bothered going back to stock all the time
Yeah I was looking at the trust since people are saying the kakimoto and stuff is pretty much like stock, how do you find the trust quiet enough to not get as much attention?
Have the Trust PEII & recon you would like it. Nice on idle, definitely not like stock but not stupidly loud...
Then as you really start to rev it up she goes wild! From what I have heard one of the more sedate jap exhausts
I've got a 3" Blitz Nur exhaust. I won't recommend it for your purposes. Has a fair bit of low rpm noise. I love it on full noise but have always considered changing for something with a little bit less noise when daudling around.
Luke
yeah might give it a go, I love the loudness of my exhust at the moment and the drone donest bother me just cbf coppin epa and having to take turbos ecus injectors etc
i have a 3.5 bee-r cat back, and it is loud (came with the car when i bought it). drone heaps. dont get it even look into it. i want to downsize or switch exhuast to something that produces a more RB burble.
you are from melb i see. i'd be happy to give you a ride if we happen to be at a meet sometime. although there are a lot of guys running the trust catback so you wouldnt have too much trouble finding a car to listen to
Ive got a 3" stainless X-Force exhaust with the bellmouth front pipe and its really good.
Gives really good results and sounds good, in no way too loud. im very tempted to put a decat pipe in actually give it a bit more grunt.
And yes im aware its not a Jap exhaust but still worth checking out, can hear the turbo spooling waaaay more now too sounds good as.
Edited by Rav3nNZ
i had a Jasma / 5 zigen 3.5" cat back & front pipe (with a bellmouth dump) on my previous 33, was very quiet down low but gave a nice scream in the higher rev range. Measured 93db @ 3500 rpm (from when i went through pits for inspection)
notice this with a lot of the Jasma exhausts that the cars come over with from Japan, they're not overly loud.
ive got a 3inch 'drift' exhaust, stainless steel from the dum, but running stock cat.. i personally think its loud, but cops dont notice my car so it must be qiuet.
i put in the silencer/resinator/restrictor in the tip of the canon when i want a qiuete drive.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
