I have recently finished buiding my r33 from a few bits and peices, engine wise its all standard with 3in exhaust and fmic, pod filter.
it runs fine but hight rpm around 4500 rpm the boost spikes to high around the 14psi mark then the timing retards and i get quiet some noise out the .
the tests i have done on the wastegate shows that at 8psi it starts to open a few mm but does not fully open untill 13psi. the turbo and waste gate are all standard so obviously the boost is way to much and i want it to run standard which i belive should be 8psi.
I was under the impression that the standard waste gate would fully open at 8psi not 13psi. is this correct??
regards adam
https://www.sau.com.au/forums/topic/313915-rb25-r33-wastegate-problem/
regards adam
How are you testing the WG?
If you are doing a static test (ie car not running and just putting air pressure into actuator) the results won't mean anything. The reason is that when the engine is running there is also some exhaust gas pressure on the WG flap that is helping it to push it open...So its opened by a combination of actuator pressure and exhaust gas pushing on it.
From what you are describing the problem may be that the WG flapper is not opening as much as it should. This could be because it is fouling on something in the dump or the linkage is binding or jamming which is stopping the WG from opening as much as it should.
first thing i did was check the wastegate clearance and its all good and not binding at all, its a non split dump and im sure its noting to do with the waste gate. im starting to think the acuator may be a r32 type hence the high pressure to open. im trying to get my hands on a r33 waste gate to test and see what happening.
I have been doing a static test, and it "does not mean nothing" im sure the test is not 100% but i dearly doubt that no exhaust gases would make 8 or so psi difference.
any other thoughts
any other thoughts
Good to see you have checked for binding etc.
Ummm, sorry but I don't agree that the exhaust gases would not make a difference.
Good luck with it...Hope you get it sorted...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
