Hi all.
Currently have a rb26dett engine with rwd sump mated to rb30 manual tranmission.
My plans are to build it up, and drop it into my auto AWD C34 1997 Stagea
Receiving soon a r32 gtr 600hp ati harmonic balancer, greddy grex n1 SS camshafts, hks step-2 valve springs, hks oil pump, hks 87mm pistons, attkd conrods, acl race bearings
Will buy the rest of the required parts later "when it's time" such as greddy head gasket kit, n1 water pump, ati pulleys, arp main-exhaust-intake-head studs, greddy timing belt & idler/tensioner bearings
Im assuming I can swap the sumps over? rb25det awd stagea sump to rb26dett engine?
I will be keeping the car as automatic. Simple as that.
Should I build up the current stagea auto box?
Or by a VL/RB30 auto gearbox already pre-built.
What size stall converter should be used?
Thoughts on electronic auto trans controllers? The ecu's will be replaced by r32 GTR Power-fc
If I buy a pre-built box it wil most likely be using ford C4 or holden trimatic, so the fast tci would be required
If the stagea box can be built for 500hp then the tcm2000 powertrain will be used.
ford/gm * TCI Fast Trans Controller - http://www.tciauto.com/Products/Electronics/default.asp
nissan * Powertrain Control Solutions - TCM 2000 - http://www.powertraincontrolsolutions.com/transcontrol.php & http://www.destroked.com/pdfs/tcu_product2.pdf
what else is required? cheers for input
https://www.sau.com.au/forums/topic/313919-rb26-automatic-gearbox-transmission/
i have always been told that power fc can not be used with auto's!
thats why I will use a completely seperate automatic transmission controller such as the TCM-2000 from Powertrain (for nissan auto gearbox) ;)
That PCS unit looks the goods, pity I can't use it with the neo tiptronic box in my stag ;)
As for sumps, yes just use your stags sump.
Can a stag box take 500hp? dunno but mine is taking a beating with 1bar through the highflow and it's stock with no inputs from ECU (haltech). Someone will be able to build them up (knox or mvautos etc), I know there is a drag car here in WA using a 4wd auto box out of a stag so it can be done (pretty sure it even has a transbrake).
for what it's worth, apart from the diff ratio, stagea/gtr/gts4 sumps are identical.
i can't comment on the auto trans issue.... except to say if I did have an auto I would still run an after market ecu. my uneducated guess is the shift control impact is overstated
Bubba your not talking about the purple 32r drag car with graphics are you? That one is not a stagea box but is auto and still 4wd. I think its from a v8 cedric or something along those lines from memory.
The stagea sump is a gtr sump, they are identical from everything i can tell except the diff gear ratios.
Fantastic - so I can drop in a tomei gtr oil baffle kit.
thanks all.
yes I will be keeping awd, Im thinking I might as well build up the current autobox then - will speak to mike at mv autos
already have the power fc, engine, q45 afm's, 550cc siemen injectors, yellowjacket coilpacks, greddy n1 cams, gtr brake kit
for 3k I got hks 87mm pistons, attkd conrods, acl race bearings, hks oil pump, ati balancer, hks step-2 springs, apexi multichecker
for another grand will finish off with n1 water pump, service gasket kit, timing belt pulley kit, then build it up
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
