hi guys, ive got a r32 gts that im going to convert to rb20det, was just wondering about the injector resistor that bolts onto the left front shock tower?(do i need this or does the de loom have one in it that looks different?) can i use my rb20de loom on a det engine? ( do i have to wire in a resistor? ), also is it ok to use a 20de ecu and put a aftermarket det chip it?
Thanks
Chris
https://www.sau.com.au/forums/topic/313941-a-couple-of-rb20det-qs/
Thanks
Chris
The injector resistor is only for low impedence RB26 injectors so if you are running standards you won't need it. Not sure about the loom, engines are quite similar so I don't see why not. No idea about using the 20de ecu, probably worth just buying an RB20DET ecu as you can get them very cheap.
Thanks
Chris
That isnt an injector resistor ballast.
Only the GTR's came with injector resistor ballast.
That silver thing on the shock tower (which looks similar to a gtr resistor ballast) is something different and not related to the injector wiring.
ohk thanks for that guys, does anyone know wat its for?? my old gtst had one
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
