hi guys, ive got a r32 gts that im going to convert to rb20det, was just wondering about the injector resistor that bolts onto the left front shock tower?(do i need this or does the de loom have one in it that looks different?) can i use my rb20de loom on a det engine? ( do i have to wire in a resistor? ), also is it ok to use a 20de ecu and put a aftermarket det chip it?
Thanks
Chris
https://www.sau.com.au/forums/topic/313941-a-couple-of-rb20det-qs/
Thanks
Chris
The injector resistor is only for low impedence RB26 injectors so if you are running standards you won't need it. Not sure about the loom, engines are quite similar so I don't see why not. No idea about using the 20de ecu, probably worth just buying an RB20DET ecu as you can get them very cheap.
Thanks
Chris
That isnt an injector resistor ballast.
Only the GTR's came with injector resistor ballast.
That silver thing on the shock tower (which looks similar to a gtr resistor ballast) is something different and not related to the injector wiring.
ohk thanks for that guys, does anyone know wat its for?? my old gtst had one
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
