  • Replies 42
You need to do a "wet" compression test as well (bit of oil in each cylinder). If compression increases, then rings are the likely culprit.
You should replace all 6 sets of rings.
but its more likely you have a damaged piston.
assuming the tst was accurate (and i guess there were other symptoms anyway....) just get the motor pulled down. there is no chance its ok with that compression and we are all just guessing at the cause
best to pull it down before buying part's, no point buying a set of ring's if the bore is damaged and need to oversize it,
i rebuilt my rb20det about 2 years ago because i had compression differences of about 30psi, turned out to be a number of thing's from melted piston's, stuck rings, leaking valve's, If its the head gasket you will hear it, if it's blown into a coolant gallery you will see lot's of bubble's in you radiator when you idle it with the cap off,
When you find out what's wrong, the first thing to do is find out why, It turned out my Fuel pump was stuffed and could only deliver 35psi max, causeing the melt down of the RB, now running an bosch 044 at 85psi fuel pressure via sard rising rate reg, Now put's out a healthy 209rwkw on 14psi at 85%duty cycle on the stock injector's,
Hope you don't find to much damage, good luck
got a stock turbos, i have a vaccum problem, my wastegates won't open, until i relocated my hoses to stock piping, and i got a .7 boost..
.7 boost, is that on that factory gauge? my factory boost gauge read's +7 even when im running 14psi, and still read +7 when i split a wastegate vac line, when it boosted out to 23psi
could a leaky injector cause the pressure to drop?
No a leaking injector will not effect the compression, will only make that cylinder run a bit richer, the easiest way i've found is check the colour of your spark plug's and make sure they are running all the same colour,
If you avcr is reading .7 your waste gate's must be working fine, if they wern't you would get alot more boost on stock turbo's,
i did notice with my stuffed fuel pump was holding my turbo back, when i replaced it my boost went from 13psi to about 19psi without touching the boost controller
ok guys... thanx for the help, what i do now is to wet test the low compression cylinders..and if pressure doesn't change il remove the cylinder header.. so i won't pull out the engine if its only the cylinder head removal right? or i still need to pull out the engine?
all spark plugs same color, brown..
Edited by andy95'R33GTR
If the comp doesn't change with the oil test then you could just remove the head with the motor still in, just be sure you do the oil test properly, with enough oil to ensure it get's around the whole piston, and not to much or this will give you false higher psi reading's, the other way to check is to presurize the cylinder with a fitting that screw's into the spark plug hole, with both intake and exhaust valve's closed on the power stroke, then listen for leak's through the intake manifold and exhaust manifold to verify a faulty valve, test each cylinder and see if their is more hissing on the cylinder's with the low compression, just remember to rotate the crack each time to get the cylinder your testing on the power stroke to ensure the cam's arn't holding the valve's open slightly,
could also be worn valve seat's causeing low compression because the gtr's run solid lifter's they need shimming to change the valve clearance, but with rb20- rb25's use hydrolic lifter's so they never need touching until one shit's it's self, or you get sick of the 10 seconds of tapping every now on start up and then and replace the f-ing thing,
If it was me i would pull the motor and check the piston's and bearing's and fit new one's anyway while you doing open heart surgery on your RB, then you know it's going to be a healthy rb, for a couple of hundred extra it's worth doing now rather than later,
You need to know how to gauge clearances for your bearing's, if your not confident doing this then leave the motor in the car and just do the head, if you get the clearance wrong it could throw a big end bearing and end the fun,
I found the ACL bigend bearing's to have a enough varience to swap and change until i had all 6 with the spec's i wanted, to the point where the thickest bearing would lock the crank up when i fitted it to one cylinder, if i had just put the bearings in any which way, the motor wouldn't have lasted 5 minute's, It's still going strong 2 year's 25,000km later with abuse all the time, shit that means another service is due on my rb,
Hope this helps out a bit,
Glad i started on an rb20, will not be so worried if i can pick up a cheap gtr with compression problem's
thanx... im not confident on change the main bearings..., i will only fix the low compression problem... ok i understand the oil test...to verify the problem..thanx
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
